[?+]: error connect cpu214 with PPI adapter
teixeol2010
i need help i need to connect to a s7 cpu 214 but i detect with the PPI cable communication error? Any idea?
Re: [?]: error connect cpu214 with PPI adapter
my idea : plug connection cable to your pc or power on your pc & cpu
teixeol2010
Thank´s for the idea but ......sania wrote:my idea : plug connection cable to your pc or power on your pc & cpu![]()
The problem is that i do the detection on the pg interface and doesn't connect to the address that appear .The cpu 214 is working OK.
kriztof
Do you use Siemens PPI adapter or some Chinese equipment?
Is your COM port integrated with motherboard or you have additional card?
Check COM settings in BIOS/Windows, check PPI adapter speed selector.
If possible test with another CPU.
Read S7-200 System Manual
http://support.automation.siemens.com/W ... _en-US.pdf
teixeol2010
kriztof wrote:Do you use Siemens PPI adapter or some Chinese equipment?
I use a Siemens PPI adapter,6ES7 972-0CB20-0XA0.V1.3
I already do the test on another equipment and it worked OK (cpu224).
Thank´s for the help .....
kriztof
Re: [?+]: error connect cpu214 with PPI adapter
It looks you have USB adapter.
Install SIMATIC PC Adapter USB Software V2.0
http://support.automation.siemens.com/W ... n/27062840
You should also update your firmware
http://support.automation.siemens.com/W ... n/14692974
teixeol2010
Thank´s for trying to help but i upgrade the firmware, and the result has the same .....kriztof wrote:It looks you have USB adapter.
It´s the same....
I have made a print screen ,please send email to send...thank´s
kriztof
First, make sure your adapter is properly installed in system.
In Windows 'Device Manager' under 'Simatic Devices' there should be listed 'SIMATIC PC USB adapter'.
Next, check that 'PC Adapter(PPI)' interface is installed in Micro/WIN.
If you still can't communicate, my idea is that you should check baudrate (PC Adapter(PPI)->Properties->Transmission rate). Default value is 9,6 kbps, maybe your PLC is set to 19,2 or 187,5 kbps.
If you don't know your CPU address click 'Communication' icon and then 'Double click to Refresh' (because it is scanning process make sure that 'Highest station number' is set to 126).
Last chance, you can use WIPEOUT tool to reset PLC to factory default (your program will be also erased!).
http://support.automation.siemens.com/W ... id=2123169.
peterc101
s7200 ports can be programmed for different kinds of communication
just pot your cpu in stop with th switch , cpu will go in default PPI communication
leave cpu in stop
now try with all baudrates
when you put cpu back in run , cpu will go back in the communication mode it was before , because port configuration happens in startup
leave cpu in stop
teixeol2010
Thank you all for your help .I have send a email with the error to Siemens Support and they send me the answer. The problem is converter MPI/PPI usb that i use the doesn't work with the CPU´S 21*.....only whit the series CPU´s 22*and above.The only way for me to connect is using a old pg from siemens..
Thank you all for your help..
