800xA: How edit BMI Library
другие контроллеры
rodomb
Post by rodomb »
Because I am starting my adventure with ABB 800xA I would like to ask about editing library.
I installed BMI library and I would like to edit this library. For example what is possibility to edit AIC control module?
AIC faceplate has faceplate elements which are in BMIStandardExt_VB_FPL 1.5-11 Extesnsion Library.
How can I redefine Limts1 and Limits2 elements???
Thanks for help.
Roman
Linkinx64
Re: 800xA: How edit BMI Library
Post by Linkinx64 »
Hi
One of the way to modify an existing aspect:
1. Copy faceplate element aspect (for example, Limits1) and paste it to the same object (copied aspect will be named "Copy of Limits1").
2. Right-click on "Copy of Limits1" and select "Edit". Modify aspect according to you requirements using Visual Basic 6 editor, deploy it and save.
3. Right-click "Faceplate" aspect and select "Config View". Click "Element" tab, find "Limits1 - Faceplate Element" in the aspect column, change it to "Copy of Limits1 - Faceplate Element".
Note: modified aspect is valid only for the existing system. If you create a new system and load BMI system extension again all the changes you're done with BMI aspects will be lost. Therefore you should save all the modified aspects using "Import Export tool" before you do so.
regards
rodomb
Post by rodomb »
Thank You, now I can learn this system more deeply :)
Regards
