[?]: PanelView Plus Terminals 700 not work
b__andrey
Post by b__andrey »
Guys urgently need advice! Never had any dealings with this product. Perhaps the question for someone ridiculous.
Does not turn on the monitor is not even lit.
Comm indicator is green, the LED blinks red fault.
Found in the manual
Quote:
Embedded software on Windows CE failed or Partner code.
Reload the firmware with the utility Firmware Upgrade Wizard (FUW)
Master firmware update).
I am embarrassed that the screen is not even a weak glow.
The issue is a programming error or a problem with the electronics?
