[?]: SIMATIC COMPATIBLE WITH WINDOWS 8
abbasmech
Post by abbasmech »
Dear all
Kindly i look for SIMATIC STEP7 and WINCC are compatible with WINDOWS 8 x64bit
Info
Faq & Info
Faq & Info
Re: [?]: SIMATIC COMPATIBLE WITH WINDOWS 8
Post by Info »
WinCC v7.2
http://www.automation.siemens.com/mcms/ ... -v7-2.aspx
Intuitive operation with 2-finger multi-touch gestures
Lepes9
Post by Lepes9 »
Hi all,
"Intuitive operation with 2-finger multi-touch gestures" means NOT that it is compatible with Windows 8. It is multitouch compliant.
Be patient. Siemens has to test a lot to make sure that their sofwares run on a specified OS.
Use Windows XP or Windows 7, it's proven. And it is VERY important for industrial applications.
Greets
Lepes9
DiVan
Post by DiVan »
viewtopic.php?f=30&t=15460
Link about SIA.INI wrote:
i used your ini file and then i got this message.
i have windows 7 home premium and the setup detected window NT!
please help (h) (oo)
info wrote:Windows 7 — Windows NT 6.1 (2009)
Windows Server 2008 R2 — Windows NT 6.1 (2009)
Windows Home Server 2011 — Windows NT 6.1 (2011)
Windows 8 — Windows NT 6.2 (2012)
and Siemens already know about next generation
SIA.INI wrote:Windows62Warning=;
Windows62Exclude=PROD3;PROD2
Windows63Warning=;
Windows63Exclude=PROD3;PROD2
Windows70Warning=;
Windows70Exclude=PROD3;PROD2
Windows71Warning=;
Windows71Exclude=PROD3;PROD2
Lepes9
Post by Lepes9 »
I think it's only prepared, but not tested yet.
Maybe I'm wrong.
Lepes9
