[?]: Upload projet from microinovation (EATON )HMI
abbasmech
Post by abbasmech »
Dear all
I have microinovation(EATON) AG HMI type XV-230-57MPN-1-10 when i try to upload project tell me there is no project although the HMI is work ok
sasko
Re: Upload projet from microinovation (EATON )HMI
Post by sasko »
Hi
If I understand your question you would like to upload the project from the panel ? If you have no MMC card inserted in the panel maybe the program is on /InternalStorage/. Try with FTP connect and find in
/InternalStorage/Backup/ zip file if constructor downloaded the project as a zip to.
abbasmech
Post by abbasmech »
sasko wrote:Hi
This is problem there is no Backup/ zip file
sasko
Re: [?]: Upload projet from microinovation (EATON )HMI
Post by sasko »
I tried to delete the backup file,yes the upload is inpossible. Try to contact the constructor,vendor... to get the program. I usaly get the project if panel die..
