Device Properties: “The device can not start, error code 10”
My notebook has only USB 3.0,no 2.0!
How to solve the problem,Thanks!
[?+]: Usb 3.0 USB PC Adapter can not be activated
nevio
ppp
Re: [?]: Usb 3.0 PC Adapter can not be activated!!!
Tested on W7x64 Home - USB MPI adapter 6ES7972-0CB20-0XA0 work with USB3 (Renesas chip)
nevio
??? MY Adapter is 6ES7 972-0CB00-0XA0 ,can't be activated.CoMod wrote:Tested on W7x64 Home - USB MPI adapter 6ES7972-0CB20-0XA0 work with USB3 (Renesans chip)
Do you have the relevant text?
DiVan
Re: [?+]: Usb 3.0 USB PC Adapter can not be activated
netbook/notebook name ?
chipset name ?
windows home/pro ?
When inserted MPI cabel to S7-CPU and USB to PC, all LEDs is ON ?
I also tested on 1 year old notebook with USB2 and USB3 - adapter 6ES7972-0CB20-0XA0 work.
Installed Step7 v5.5 and TIA Portal v11. No aditional driver.
In setting PG/PC select USB MPI.Auto
chipset name ?
windows home/pro ?
nevio
dell vostro 3360
WIN_7_ULTIMAT
When inserted MPI cabel to S7-CPU ,the MPI and POWER LEDs is on.Continue into the PC USB, USB LED flashing after a few seconds turns off.
I installed Step7 v5.5,No aditional driver.
WIN_7_ULTIMAT
