[LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.2
Тools, Elcad, Eplan, ...
sadefa
Post by sadefa »
Hello 2 all
taoday i have the new ePlan v2.2
Enjoy ;)
Torrent
EPLAN Electric P8 2.2 HF1
http://rutracker.org/forum/viewtopic.php?t=4360514
EPLAN Pro Panel
http://rutracker.org/forum/viewtopic.php?t=4366644
or
EPLAN ELECTRIC P8 2.2
DESCRIPTION
Show
EPLAN Electric P8 offers unlimited possibilities for project planning, documentation, and management of automation projects.With your choice of graphical or object orientation as well as refined platform technology, this high-end system is breaking new ground in electrical engineering. Its unique functional scope and direct connection to fluid and EMSR technology makes interdisciplinary work a reality.
Data from earlier planning phases can simply be imported using interfaces like ODBC, XML, or Excel – for consistency and perfect integration.
In other words: To shape your future, use EPLAN Electric P8.
EPLAN platform strategy: The modular platform provides core functions that are required in electro-CAE as well as in fluid or instrumentation & control engineering. The advantage of this is consistent data management and uniform processing in all disciplines.
Torrent http://rutracker.org/forum/viewtopic.php?t=4235126
links hotfile.com & rapidshare.com
Show
EPLAN P8 PRO PANEL 2.2
DESCRIPTION
Show
EPLAN Pro Panel Professional: Virtual enclosure layout in 3D
EPLAN Pro Panel Professional convinces through its deep degree of integration in the EPLAN platform and utilizes its manifold basic techniques such as the EPLAN device concept, the macro and options technology, access to the EPLAN Data Portal, etc. The design approach is individual: Optionally on the basis of a schematic or directly as layout of the enclosure in 3D. The devices provided for the mounting layout are displayed well-structured in Navigators or lists. During placing the system checks whether the positioning is carried out on the correct mounting panel.
The innovative eTouch technology allows components to be comfortably aligned and positioned exactly. Installation regulations and minimum spacing to manufacturer specification are taken into account as are the correct positioning of devices, wire ducts and mounting rails, including collision checks. The overview of all the designed devices and components allows the items to be checked simply on the basis of the parts data. Reports and bills of materials contain precise information also about items that vary in length such as wire ducts or mounting rails. Exact specifications therefore for manufacturing and mounting. Changes in the schematic or mounting layout are included in the entire project. The system informs interdisciplinarily and updates the associated drawings, bills of materials and legends automatically if desired. Thus ensuring uniform and consistent data that are always up to date.
Complete consistency
The software makes professional 3D layout planning easy even for the occasional user. Production relevant NC data for holes or cutouts is taken account in the 3D model and can be further processed. In addition to associative mounting diagrams special drilling templates for manufacturing can, for example, also be created. Modifications to housings, doors or mounting panels are transferred directly to the NC production systems via an NC interface. The deep manufacturing integration is also continued in the virtual wiring of the enclosure. The results of the length-optimized virtual wiring and cabling can in turn be used to optimize the schematic. The new quality in enclosure engineering covers all the phases of product development. The realistic 3D representation ensures high-quality data for manufacturing, mounting and operation. It facilitates the consistent creation, provision and maintenance of the documentation and accelerates the product engineering process persistently.
Manifold possibilities
EPLAN Pro Panel Professional provides manifold possibilities for the field of integrative enclosure planning, pre-assembly and production.
Added value at a glance
Benefit from numerous advantages for the virtual enclosure layout in 3D.
Modularization – the tailored fit for your system solution
Adapt EPLAN Pro Panel Professional perfectly to your workflows in engineering, technical preparations, manufacturing and mounting.
Product videos
Get an insight into EPLAN Pro Panel
System requirements
EPLAN Pro Panel Professional works with all standard Windows operating systems.
links hotfile.com
Show
or equal mirror
links Rapidshare
Show
EPLAN P8 FLUID 2.2
DESCRIPTION
Show
EPLAN Fluid supports fluid engineering with automated documentation. Simple handling, numerous test functions, and standard support make your design efficient – from now on the system assumes time-consuming standard tasks.
Compared with conventional, mostly CAD-based systems EPLAN Fluid comes with unique logic functions and automatisms that accelerate your fluid planning. The modern user interface with extensive drawing functions helps you familiarize yourself with its full potential – of course with the complete data stock from the predecessor system fluidPLAN. The autoconnect function applies to all connections that can be provided and analyzed with logical properties. This means you have an overview of all components, including the small parts like connectors, hoses, and pipes – and therefore a firm grip on the costs!
The new Engineering platform is your key to the future, providing core functions for fluid, electrical, measuring, and control engineering as well as CAE for electrica systems. Based on a unified platform all systems are suppliedfrom the same database. From now on multiple data entries and inconsistencies are history.
Besides a unified database the platform also includes basic functions like thegraphical editor (for circuit diagrams, fluid plans, process control group plans), a unified rights management, the viewer, online/offline foreign language transla-tions, and the comprehensive audit system. The unique framework concept deliversimpressively fast results – not least of all owing to the unified look & feel throughout all applications.
links hotfile.com
Show
EPLAN P8 PPE 2.2
DESCRIPTION
Show
EPLAN PPE is the optimal tool for successful international collaboration in the planning and realization of electrical, measuring, and control system projects. Besides the maximum data and service compatibility, also the wide range of powerful interfaces, utilizing the full capacity of modern communication channels, supports collaboration by the whole project team over all the planning stages. This mobility and flexibility is particularly effective in the internal environment. For example, EPLAN PPE can also simplify and automatically advance adaptation and modernization processes at your own company. The new EPLAN technology provides a platform where fluid, electrical, measuring, and control engineering caninteract directly in interdisciplinary collaboration.
The overall concept behind EPLAN PPE is aligned to the present demands of measuring, control, and automation technologies. If work is to conform to the standards, a process control group concept based on NAMUR recommendations must be integrated. These NAMUR specifications for process control engineering are fully supported by EPLAN PPE. Its practical orientation and ease of use make EPLAN PPE an efficient tool for modern process plant engineering. Established methods and innovative developments have been combined into an extremely powerful and efficient solution.
The new modular Engineering platform technology is your key to the future, providing core functions for fluid, electrical, measuring, and control engineering as well as CAE for electrical systems. Based on a unified platform all systems are supplied from the same database. From now on multiple data entries and inconsistencies are history.
Besides a unified database the platform also includes basic functions like the graphical editor (for circuit diagrams, fluid plans, process control group plans), a unified rights management, the viewer, online/offline foreign language translations, and the comprehensive audit system. The unique framework concept delivers impressively fast results – not least of all owing to the unified look & feel throughout all applications.
links hotfile.com
Show
EPLAN P8 2.2 CRACK-TEMP1.rar
http://eplan-eb2.ys168.com/
http://bbs.e10000.cn/a/a.asp?B=203&ID=1220778
before run setup.bat need create folder c:/user/public/EPLAN/commom/
setup.bat
Show
@echo off
if "%OS%" == "Windows_NT" goto winnt
echo (h) Chinese text L-¬¦¨, -¬ãç¦ãWIN XP TL¦-¦--ö--. Not compatible OS
goto end
:winnt
echo (h) Chinese text ¬+¬T-ö¦¬ã¬ãç¦ãWIN32 ¦¦=¦ã즦¬¸-¦¦°ã¬
pause
net stop hardlock
del %windir%\system32\drivers\*.fst
del "C:\Documents and Settings\All Users\Application Data\EPLAN\Common\*.*"
echo (h) folder C:\Users\Public\EPLAN\Common\ not Exist !!!!
del "C:\Users\Public\EPLAN\Common\*.*"
echo Windows NT/2000/XP (h) Chinese text ¬T-ö¦¬--+-áã
copy hardlock.sys %systemroot%\system32\drivers\
copy *.FST %systemroot%\system32\drivers\
copy *.EGF "C:\Documents and Settings\All Users\Application Data\EPLAN\Common\"
copy *.EGF "C:\Users\Public\EPLAN\Common"
net start hardlock
echo (h) Chinese text ¬T-ö¦¬=ú¦ã--+-ãì¦û-¦¦°ãá
PAUSE
but it not stable
Kasperky Ok and Avast OK
Additional tools:
Microsoft .NET Framework 4
http://www.microsoft.com/en-us/download ... x?id=17718
:!: Video tutorial: How to install EPLAN :!:
van8x10
Re: [LINK]: EPLAN P8 2.2
Post by van8x10 »
Dear Mr Sadefa, thank for your sharing (clap) . I've downloaded and installed, but it seems to be only for Win 32, so can you share the SW with for Win 64? (tyou)
TheDuke
Post by TheDuke »
There is no 64 bit version of Eplan P8.
greets
TheDuke
van8x10
Re: [LINK]: EPLAN P8 2.2 x32
Post by van8x10 »
van8x10 wrote:To TheDuke: I mean the v2.2 doesn't run with Win7x64 as the v2.1.6 (SP1). I've installed the v2.2 in PC with Win7x32 and it run OK!
To Sprudel1968: do the same v2.1.6, (patch for Windows Vista/7 (x32/x64): https://rapidshare.com/#!download|650p1 ... r|1476|0|0), using file SN-U10066.EGF shared by PDLFFALF ( see http://www.plcforum.uz.ua/viewtopic.php ... 462#p55679)!
sadefa
Post by sadefa »
TheDuke wrote:There is no 64 bit version of Eplan P8.
I do not think so ... this is a x64 bit version. I have no idea why the admin edited my post ;)
I have the same on my PC ans mine is x64
Boxy
Post by Boxy »
Does some have it on Rapidshare or Uploded.to?
thx
van8x10
Post by van8x10 »
You should better use Hotfile AutoDownloader or Premium Account :wink:
eagle25
Post by eagle25 »
sadefa wrote: I do not think so ... this is a x64 bit version.
version 2.2 is running?
not work on my pc (wow) , I need help.
sadefa
Post by sadefa »
Dude, it has been so since 2.0,
look at section system requirements @ the news pdf
Risky73
Post by Risky73 »
It seems that ePlan v2.2 runs correctly with crack from topic viewtopic.php?f=7&t=18462 :) For those who don't understand Chinese instructions (like me), install eplan and then run "setup.bat" and after restarting PC ePlan will run without limitations.
Now waiting for ProPanel from topic viewtopic.php?f=7&t=18558 (for the moment parts 5 & 10 are problematic).
BULBO
Post by BULBO »
Hi,all
I installed Eplan P8 2.2.5 and run with new crack.
I have only a question about x32. During the installation the programs show win32 and I do not understand why.
When I run the program I have an error message but Eplan function always.
The error message is:
Because of a conflict Hardware, Eplan can be run on the system only with limited power. [Error 4521].
To resolve the problem, contact your dealer.
Please Help me.
P.S.
I run a full installation of Eplan package.I have only moved the new license file in the Common folder.
Should I follow a special procedure?
Now the version 2.1.6 gives me the same error but it works.
I think it is a problem of the crack.
sadefa
Re: [LINK]: EPLAN P8 and PANEL v2.2 x32
Post by sadefa »
Acording to the instructions, from the news pdf, eplan platform is running on 64bit systems. I am sure more than 100% that since v2.0 eplan platform was compatable with 64bit systems.
eagle25
Post by eagle25 »
HELP (h)
problem Win7X86 or x64
when I click setup.bat, do not install the dongle and erases the sn-U10066.egf the c: user / public / EPLAN / commom /
copying again the sn-U10066.egf
For validation is not available a adequate Dongle.
Barba
Re: [LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID v2.2
Post by Barba »
Thank you for a great share!
I was wondering is there someone who has "copper module" for Pro Panel professional?
cacfmarinho
Post by cacfmarinho »
I have the same problem ..... (h)
what i should do ?? (oo)
bjekas
Post by bjekas »
In my case the file sn-U10066.egf is there but I still have the problem that the dongle is not available.
In the version 1.9 and 2.1 the crack works but I cant create a project with more than 10 pages of schematics... says that the maximum number of logic pages have been reached! Go figure!
Im using windows XP btw...
Edit:
Problem solved! Aparently the old cracks were messing with the new one. I installed EPLAN 2.2 in a clean virtual machine and the crack worked like a charm. The 10 page limitation thing is over also.
Big thanks to Risky73 for the help and everyone that replied to me. Thanks guys, you're the best
(pgood)
sadefa
Post by sadefa »
bjekas wrote:In my case the file sn-U10066.egf is there but I still have the problem that the dongle is not available.
I gues you are not starting the program as a proffestional licensed (the pop up screen whe the program is started)
expertsuresh
Post by expertsuresh »
Dear Sadefa
After running setup.batch, i am getting following message as attached.
Anything i am missing. For setup, i have done from setup.exe after unzip.
please guide me.
thanks in advance
the following error happens.
after running batch file, first it asks
press any key to continue
after pressing it is showing system error 5 has occurred.
access is denied.
could not find c:\windows\system32\drivers\*.fst
The system can not find the file specified
c:\users\public\eplan\common\*.* are you sure (y/n)
after pressing yes
system can not find *.fst
eando
Post by eando »
Hi everybody,
Is it safe to install 2.2 over 2.1 in the same computer?
Will 2.1 stop working? Are both cracks compatible?
Thanks,
R
bjekas
Post by bjekas »
Hi Eando,
If you install 2.2 you'll get both version in windows and you will not have a problem with installation... I had 3 versions of Eplan in my pc and they were ok... but with the cracks is another history. I installed this Eplan 2.2 after having the 1.9 and 2.1 versions and the crack for 2.2 doesn't work. I uninstalled all versions of Eplan, removed all license keys and tried to install 2.2 again... no luck with that.
Then created a clean virtual machine with windows xp and installed EPLAN 2.2 and the crack worked like a charm.
I've read other people complayning about not getting the crack to work and I think this is the reason! But again, this was my problem... cant say for sure that there is a crack incompatibility.
eando
Post by eando »
Hi Bjekas,
Thanks a lot for the information. I had thought about installing the 2.2 in an XP virtual machine, but I wasn´t sure if the crack would run over XP.
Best regards !
titus95
Post by titus95 »
For me the same crack for the 2.1 and 2.2 is ok with win7 x64.
popi
Post by popi »
hallo titus 95.
can you reupload your Eplan crack for win 7 x64?
Boxy
Post by Boxy »
Does some one or our Specialist Sadefa have Eplan Fluid and PPE on Rapidshare?
(tyou)
eagle25
Post by eagle25 »
hallo titus 95.
What is the procedure to install the crack?
titus95
Post by titus95 »
Adapted from an another post (viewtopic.php?f=7&t=13472&hilit=2.0.5.4602&start=50)
1. Install Eplan P8 2.2, required setting the "management rights" from the "examples / basic data" if the installation does not deliver, it just pops up and the message: "Information Rights Management is currently unavailable. The database file is missing or broken access to the file. As to infringement can not be established unequivocally, it is impossible to run the program.
2. Copy the license file (SN-U10066.EGF) C: \ User \ Public \ Eplan \ Common \;
3. SN-U10066.reg run the file and add data to the registry;
4. Run the driver installation Multikey - emulator from your Release \ MultiKey64 \ install.cmd;
5. Run a test mode in Windows 7 x64 dseo13b.exe running the program and the radio button for "Enable Test Mode".
By the way, just note that here also provides the opposite effect "Disable Test Mode", disable the test mode;
6. In one corner will display "Test Mode Windows 7 Rekease 7600;
7. Run the program dseo13b.exe;
8. Add a digital signature for the driver Multikey.
To do this, select "Sign a System File" and enter the filename including the full path C: \ Windows \ System32 \ Drivers \ multikey.sys, test mode does not turn off!
9. Reboot your computer;
10. Start the EPLAN Electric P8 2.2 and enjoy his work
eagle25
Post by eagle25 »
titus95 wrote:Adapted from an another post (viewtopic.php?f=7&t=13472&hilit=2.0.5.4602&start=50)...
help, crack does not work
"Run the driver installation multikey - emulator from your Release \ MultiKey64 \ install.cmd;" does not install.!
niila
Post by niila »
download titus95's link and same procedure as before 2.1
titus95
Post by titus95 »
eagle25 wrote: help, crack does not work
I had the 2.1 installed and operational, when I put the 2.2, all versions did not work any more. I did install it as described, me too with the default installation of multikey, but everything works again 2.1 and 2.2.
On another PC that had the 2.1, I just change the SN-U10066.EGF by the new and 2.2 has functioned immediately.
Both pc under windows7 x64.
popi
Post by popi »
Hallo
My crack don´t work. I have Win 7 64 Bit with SP1 instaled on new pc.
Before I instal I set UAC to minimal, my antivirus Eset turn off.
Then Instal Eplan p8 2.2. I Used crack procedure from Titus 95.
Win is in test mode release 7601. And crack don´t work.
Hav You any idea to use Eplan crack?
Than yoy
"Sorry for my english :) "
BULBO
Post by BULBO »
Hi all,
ok my situation about 2.2 is:
Eplan P8 works without problem.Sometime I have the same message
(Because of a conflict Hardware, Eplan can be run on the system only with limited power. [Error 4521].
To resolve the problem, contact your dealer.) but I work.
For me the problem is in the dongle.
kostyc
Post by kostyc »
ENG: Download torrent button is not activated. Please unzip the archive and perezaleyte torent. :(
RUS: Не активна кнопка скачать торрент. Распакуйте пожалуйста архив и перезалейте торент. (oo)
Best regards.
Bonavox
Post by Bonavox »
BULBO wrote:Hi all,
Yes, I have working 2.2 too. Only in vitrual PC with Win7 x86. Did not try with Win7 x64.
But I am still waiting what will hapend after month after instalation?
Does anybody know? Will 2.2 stop working or not? Is 2.2 sending some reports to the ePLAN company via internet?
I saw that there is Data Portal integrated into 2.2 but when I logged in there was information that I am using WUP0U10066 license (I am not so happy for that).
I am waiting with using 2.2 instead 2.1 because there is new database format (you have to convert existing projects) and there is no way back from 2.2 to 2.1 if it will not work 100% propertly.
jalves
Post by jalves »
Hi to everyone.
My OS is Win7 64bits and I have tried to install P8 1.9.11, P8 2.05 and also P8 2.2 following the instructions provided but neither one has a clear crack that works, so I ask: what version has a good crack that really work? I realized that some get Eplan running and others like me, not. What is the real process to install it?
Thanks a lot.
gksl35
Post by gksl35 »
Эй, ребята! Я не могу скачать его с торрента. (sbutton) (wow) (nuser)
Hey Guys! I can not download it with torrent.
KAUKa
Post by KAUKa »
На Windows 7 SP1 Pro&Ult x64 и Windows 8 Ent x64 работает только с Multikey.sys x64 версии 0.18.1.0!!!
brepo
Post by brepo »
TitusTheFoxII
Post by TitusTheFoxII »
brepo wrote:eplan 2.2 x64 work http://speedy.sh/cHNxJ/eplan2.2x64.rar
same like Titus95-crack
Win is in test mode release 7601 and the crack don´t work.
There is a possibility to run EPlan 2.2 under Windows 7 X64, like not in Test Mode?
Bonavox
Post by Bonavox »
Bonavox wrote: But I am still waiting what will hapend after month after instalation?
That's it. It stopped to work after month. There is no license it says. It is not permanent crack ...
titus95
Post by titus95 »
Bonavox wrote: That's it. It stopped to work after month. There is no license it says. It is not permanent crack ...
This is true, but just delete the file SN-U10066.EGF (C: \ User \ Public \ EPLAN \ Common \) and replace the original one supplied with the crack.
brepo
Post by brepo »
put all files with folder MultiKeyx64 to: C:\Windows\System32
and run install.cmd ... (administrator mode on W7 x64)
popi
Post by popi »
Hi all. I have problem with Driver instalation Virtual USB MultiKey on win 7 PRO 64.
version Virtual USB MultiKey is 0.18.2.4
have any Idea run correct Virtual USB MultiKey ?
Thanks for reply.
(tyou)
Boxy
Post by Boxy »
titus95 wrote:This is true, but just delete the file SN-U10066.EGF (C: \ User \ Public \ EPLAN \ Common \) and replace the original one supplied with the crack.
May be , also check the settings from the firewall!
Block all from Eplan (EPLAN W3, HASP etc...)
trak_inas
Post by trak_inas »
I can't get it working. All instaled correctly, but i have an error, it says there is not an correct dongle available.
Can you please help me
Bonavox
Post by Bonavox »
Well, still not 100% sucessfull ...
I installed new Win 7 x64 in virtual PC, installed clear instalation of ePLAN Electric P8 2.2.5
Turned off the internet connection, applied the patch for x64.
But after first run of ePLAN it said "there is not possible to check online the license validation" and "there is not valid license".
And that is all. End
The rest starts are succesfull, even there is still message "it is unable to check licence, ePLAN will run with not full power [error 4521]"
And during the work there is jumping window "[error 4521] please contact salesman"
cuervo2k
Post by cuervo2k »
Hi, has anyone managed to install the emulator in windows 8 64bit? when I install the driver I get the error "Devcon failed", I do everything as administrator
Does anyone know why this happens if windows 7 works perfectly?
eplanner
Post by eplanner »
Hi, I had same problems like some of you.
Tried with that multikey from above link (v0.18.2.4):
- x64 version did NOT work on win7 x64 (error in device manager an/or license manager)
- x32 version did NOT work on win7 x86 (devcon error)
But it DOES work with an older Multikey (v0.18.1.0). Tested for x86 and x64. on win7 x64 SP1 and Win7 x86 SP1. (All in VMWare)
Just do it like titus95 said. Begin with a normal installation of eplan. uac off.
kra101
Re: [LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.2
Post by kra101 »
Hi Sadefa,
The same crack will work for Eplan P8 2.2 and Pro Panel as well?
Thanks in advance,
kra.
trak_inas
Post by trak_inas »
eplanner wrote:Hi, I had same problems like some of you.
Hello
Can you please upload the files needed, because i already try with multikey (v0.18.1.0) and i have the hardlock in the device manager, but eplan says it isn't an correct dongle available
