[?]: what the difference between Koyo DirectSoft 5
другие контроллеры
omar zedan
Post by omar zedan »
Dear All
I install Directsoft 4, when I open DSLaunch4 I found directsoft32 programming 4 under Application item (in DSLauncher there are 4 items Application, Utilities, Projects and Comm Links).
But when I install Directsoft 5 , when I open DSLuanch5 I found the same 4 items (Application, Utilities, Projects and Comm Links) but the dirctsoft32 did not appear under application item?
Also please what the difference between dirctsoft 32 and directsoft100?
johnmorley
Re: Koyo DirectSoft 5
Post by johnmorley »
Dear omar zedan
DirectSOFT100 gives you the same features as the full version of DirectSOFT5 but allows only 100 Words of ladder code to be downloaded to the PLC. It is a free version of DirectSOFT5.
If you have installed DirectSOFT100, the program files are probably different.
Cheers
John :)
omar zedan
Re: [?]: what the difference between Koyo DirectSoft 5
Thanks John
