800XA : lost my entire backup archive
другие контроллеры
tim00
Post by tim00 »
hello: After a hard drive crash , I've lost my entire backup archive pls can any one you help me and tell me HOW CAN RECOVER MY PROGRAM FROM CPU ??!!!! :? (oo)
Abelky98
Re: 800XA : lost my entire backup archive
Post by Abelky98 »
Try slaving it with a functioning computer. Take out the crashed hard drive and get a matching adapter with usb port for it. Plug it to a functioning computer through the usb. if the hard drive is not totally damaged, you will see all your files. Copy them to a different storage medium. Then you can proceed from there.
Linkinx64
Post by Linkinx64 »
Your question is lack of information:
1. What kind of backup? 800xA full system backup or Control Builder project only?
2. What did you mean under "recover program from CPU"? PLC? If so, what kind of PLC/CPU?
3. Was that external drive or system drive (Windows with 800xA)? If that was external - why do you need backup? You have system running, so you are able backup it again.
Please clarify...
tim00
Post by tim00 »
first big thank gentlemen's for the answered
1. backup for Control Builder project only
2. now the system running, and i want to RECOVER MY PROGRAM FROM PLC AC800* :oops:
Linkinx64
Post by Linkinx64 »
If recovered after failure 800xA system is running the last downloaded version of the project must be in the Control Structure... of course if you did not create a new system.
If you did so - contact ABB, they maybe will send a specialist with PLC memory dumping and conversion toolkit on your site :D
