[?]: EPLAN 2.2 (WARNING message )
Тools, Elcad, Eplan, ...
chakotay
Post by chakotay »
Hi guys,
there is a major problem with eplan 2.2 and all dongle emulation tricks.
They rewrote the complete HASP Interface, and there is a hoax message included.(yes, 2.2 only works with the latest)
If you are lucky, you will get it work for 30 days, but "DO NOT CALL THE HOTLINE IF YOU GET THIS ERROR:"
here in german:
Aufgrund eines Hardwarekonfliktes kann EPLAN auf Ihrem System nur mit eingeschräkter Leistung ausgeführt werden.
[Fehler: 4521]
Bitte wenden Sie sich zur Lösungen dieses Problems an Ihren Händler.
Error: 4521 means "Dongle Emulation found".
After that message Eplan starts without any problems.
So if you reproduce your original dongle to a software dongle plz don't call the hotline before anyone has a solution for that.
greets,
chakotay
chakotay
Re: EPLAN 2.2 (WARNING)
Post by chakotay »
Temp Solution:
(all done with multikey.sys / tested with 32/64Bit.)
After 30 days it asks again for the serial number.
Enter your serial you'll get a message: License file is corrupt.
Delete your license in user/all/eplan/common and enter the serial number again.
Now it will work for 30 days again.
This is not a comfortable solution, but it works.
Greets,
chakotay
Sprudel1968
Re: [?]: EPLAN 2.2 (WARNING message )
Post by Sprudel1968 »
someone has V2.2.5 with crack?
TheDuke
Post by TheDuke »
Hello chakotay,
thank you for this information, please keep us up to date.
greets
TheDuke
Sprudel1968
Hello, seeking emulator for EPlan 2.2.5
Can you help me?
Thank you!
chakotay
Post by chakotay »
If you are using the 32 bit dongle emulator called "HASP HL Emulator" instead of multikey.sys, the new Licence Manager will not allow you to install the device driver. So it is time to say "Goodbye" for this emu.
Note: Eplan 2.2x will be the last x86/x64 bit version of Eplan P8. Newer versions = 64bit only.
xflash
Post by xflash »
It is such sad a bad news, hope there is update crack~
