REQUEST SIMIT V7.0
Anybody ?
http://www.industry.siemens.com/service ... order.aspx
https://www.automation.siemens.com/mcms ... fault.aspx
[LINK]: SIMIT V10.0
Info
- Faq & Info
georg_demmler
Re: [REQUEST] SIMIT V7.0
i`m looking for the software simit V7.0. Is there someone, who share the software.
Thanks in advance
Thanks in advance
Simulation Software SIMIT V* Available for Download
v8, v9
https://support.industry.siemens.com/cs ... ankingDesc
but without crack
v8, v9
but without crack
georg_demmler
thank you very much for your replay.
George
George
chriss_russell
how to crack?
Re: [REQUEST] SIMIT V10.0
"New licensing model" - not use this softhow to crack?
нафиг не нужен такой софт
https://support.industry.siemens.com/cs ... sing-modelWhat's new with simulation software SIMIT V10.0
SIMIT V10.0 offers you several additional features that noticeably increase the efficiency
and make the simulation setup even faster and easier:
New licensing model
- Future-oriented licensing model
Floating licenses
One dongle instead of serverals dongles for one plant
1. General information on the new licensing model
With SIMATIC SIMIT V10, a new licensing model based on a USB dongle has been introduced.
The dongle is part of the licensing process and always needs to be inserted.![]()
It also serves as a secure and central storage location for all SIMATIC SIMIT floating licenses.
If the dongle or a required license is not found in the entire subnet, the simulation is stopped![]()
and the software can only be used with restrictions until the dongle or the license is detected again.
2. USB dongle and licenses
The USB dongle is labeled with a serial number in the format "3-xxxxxxx".
This serial number is unique and is used to create the licenses based on the serial number.
In the case of a follow-up order, it is therefore always necessary to specify the dongle serial number.
Note
WIBU-SYSTEMS, the dongle manufacturer, is a leader in the field of software product protection.![]()
3. No dongle inserted
If the software does not detect a dongle or required license, the simulation is stopped.
You are informed of this by a message on the operator station.
The result is that the right to use the software is no longer given without a valid license
and a new license or dongle therefore needs to be ordered.
Note
The dongle is searched for throughout the subnet.
This means that it is sufficient to connect the dongle to a PC, for example in a secure server room.
Because the dongle contains all licenses and is therefore essential for the licensing of the plant,
it is recommended that the dongle is stored in a secure area with restricted access.
