[?]: GE- FANUC 90 -30 cable for the cpu 331
Please am looking for information diagram to build a programing cable for the cpu 331. one end should be Db9 while the other end should be Db15.thanks
vlad2006gr
Re: [?]: GE- FANUC 90 -30 cable for the cpu 331
Need RS232 to RS422 converter.
See:
http://www.artisan-scientific.com/info/ ... manual.pdf page 271
https://www.hmisource.com/otasuke/qa/gp ... gef1_1.pdf
http://www.qualitrol.com/documents/Seri ... Manual.pdf
Good luck!
See:
Good luck!
thanks for the reply, my laptop does not have serial port am using prolific usb to serial converter,and i donot have a miniconverter what i need is a diy arrangement to connect my 9 pin db9 connector to the db15 connector. i have an rs232 to 422 converter
thanks
thanks
