Hi
I want to install Step7 v5.5 in a drive other than C.
The problem is that the Setup program doesn't ask where to install the Step7 v5.5, just the PCT.
I searched with the setup.ini file if there are some options, but no luck...
Has anybody tried & succeed to install Step 7 in a different drive than C?
If so, how?
[?]: Step7 v5.5 install to another drive
Re: [?]: Step7 v5.5 install to another drive
Hi
well, yes, I was aware of that...
My bad for not making it clear in the first post, but I have Step v5.5 SP2, which doesn't have this option...(Typical, Minimum, Custom)
It is not possible to install Step7 v5.5 under Windows 7 64-bit, so I will not be able to upgrade to SP2.
The same with SP1.
Anyway, if someone has any idea I'll be happy to know!
The same with SP1.
Search deeply here.You will find the way...
Hi Umencho
Can you please post a link to this which you are referring?
I've been looking but to no avail
