[?+]: ABB red triangle
другие контроллеры
omar zedan
Post by omar zedan »
Dear All
How can I delete the red triangle from hardware (Modules) of ABB AC800 M Builder?
Note1:- the error mesage is Wrong module type (I use DI801 and define DI801 in software).
Note2:- the module work correctly in another PLC also I use Clear Latch unit Status BTN.
Linkinx64
Re: [?]: ABB red triangle
Post by Linkinx64 »
"WrongModuleType" - a very common error when something does not right in the module hardware configuration in the Control Builder AC 800M.
Typically, when physical module location (position on Modulebus) is different from what is specified in the hardware settings. Check your hardware configuration more carefully.
omar zedan
Thanks friend
