I've got VM XpMode to run 32bits softwares, since my machine run in Win7 64 bits, so I try install Wincc Flexible 2008 in the Xp mode and this errors occur:
WinCC flexible Error
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action _F4F465C5_0854_4B21_92CB_8CBCC15B626E, location: C:\WINDOWS\system32\OpcEnum.exe, command: /RegServer
The following mesage appears:
Feature transfer error
Consult Windows Installer Help(Msi.chm) or MSDN for more information.
And the setup finishes without installing.
How I fix it?
[?]: Error when install wincc flexible 2008 in XP Mode
Avtomatvs
Re: [?]: Error when install wincc flexible 2008 in XP Mode
Use WinCC Flexible 2008 SP3 in x64 modeAvtomatvs wrote:How I fix it?
Engineering System:
Microsoft Windows XP Professional with SP3
Microsoft Windows 7 SP1 Professional, Ultimate, Enterprise (32/64 Bit)
Avtomatvs
I can open the project create in WinCC Flexible 2008 SP3 in x64 mode in the WinCC Flexible 2008 SP3 in WinXp 32bits?
canAvtomatvs wrote:I can open the project create in WinCC Flexible 2008 SP3 in x64 mode in the WinCC Flexible 2008 SP3 in WinXp 32bits?
