[?]: floppy image with authorization for Step 5 v7.23 HF2
malinowykrul
I need floppy image with authorization for Step 5 v7.23 HF2
Homeroid_BL
malinowykrul
Re: [?]: floppy image with authorization for Step 5 v7.23 HF
I can`t create yellow disk, please look for my screen.
What to do in following steps to create yellow disk with licence to step 5?
please help,
I must load authorization in virtual machine in vmware and I can`t do it.
please help,
How
http://plcsim.narod.ru/Yellow_Disk.htm
basic Yellow_Disk_Images IMA file for WinCC_v51
WinCC_v51_Yellow_Disk_Images.zip
1. restore it to floppy
2. after this install key to disk A:
https://mega.nz/file/vaxDnaoT#esLN0c4YE ... uVFYLuQu58
TTTRRRRRR...... TTTRRRRRR...... TTTRRRRRR...... TTTRRRRRR...... - If floppy is good authorized
for old short key use old programm Siemens.exe with old keys
Sim_EKB_2006_11_14a.zip
https://mega.nz/file/PCoHSQib#9pYpVBZZE ... Z44FmrxjKA
see viewtopic.php?f=30&t=218
https://mega.nz/file/vaxDnaoT#esLN0c4YEu2lgWDqCrJHZpaRZf0KARzH2uVFYLuQu58for old short key use old programm Siemens.exe with old keys
https://mega.nz/file/PCoHSQib#9pYpVBZZEbXvKFhphLRX-YNQsHaXal7HUZ44FmrxjKA-
malinowykrul
Please create for me yellow floppy with licence for Step 5 v7.23 HF2.
I try from a few days and probably something I do wrong.
How to run Step 5 after creating licence?
deltafox1002
It's importend to install the licence on C: otherwise STEP5 can't find the licence. I had the same problem.
JBflyer
Re: [?]: floppy image with authorization for Step 5 v7.23 HF2
I just acquired a machine with a Simatic S5. I found the software and installed on a Virtual Box with Windows XP. My download did not include the Authorization disk or files. I tried the links shown in precious posts on this topic but cannot see the files. Are they no longer available? I need access to the PLC program to troubleshoot issues in the machine. Right now I feel like I'm stuck.
Update
- Forum Community
Sim_EKB_2006_11_14a .zip with old Siemens.exe and keyset
