CNC 840D (NPU572 + PLK315-2DP + MMC103)
machine is not working 6 years, respectively, the battery has to NPU572
there is a floppy disk from the manufacturer (BOSH) to the project and archives PLC PLC and NC.
When you turn on the MMS message to the lack of communication with the NPU ...
LEDs SF on three modules perefiriynyh IMR300 ...
When trying to connect to the laptop via step7 x122 is also lack of communication ...
According to the manual cleared the PLC memory, LEDs are turned off, step7 saw PLC, the MMC has left a message that there is no connection ...
I'm trying to fill in Architectural project by a PLC said step should be 131kb low memory and in Col. 48, and third, respectively, filled with blocks and get errors.
With simocom trying to fill the archive PLC (23234PLC.ARC) of the same recorded message and then running out of memory ...
Tell me which way to go further?
