[?]: Personal problems with TIA Portal
buburoboy
Post by buburoboy »
Add :?: about problems with TIA Portal to existed topic
Russian wrote:Задавайте вопросы по Порталу в существующую тему об этом - мы все бэта-тестеры
[?]: Testing TIA Portal v11 SP1 (We all beta-testers :)
viewtopic.php?f=1&t=15487
Hello everyone,
I downloaded the torrent file (2.7GB), the S7 TIA V11 Pro, but when I tryed to run it (after running the Iso Buster), I click the start and I get an error, "SIA.ini" not found, does anyone got the same problem?, or know what should I do?
Thanks and best regards
Re: [Link]: TIA Portal V11: Step7 + Flex + WinCC v11 + SP2
buburoboy wrote:Hello everyone,
Unpack ISO to folder and install from folder.
mickyblu
Post by mickyblu »
Hello guys,
I downloaded the torrent TIA_Portal__rutracker.org_.t4055136.torrent which contains both STEP7Pro_TIA_W7_64.iso (4,054,986,752 bytes) and WinCCPro.iso (4,795,711,488). I installed Step7 OK no problem but when i try to install WinCC i get error MSI File intialization failed:ERROR_OPEN_FAILED.
I dont know if the file is corrupted? maybe i try to download again torrent
Thx
Mickyblu
Here is the error from the SIA install log
19:53:33|... |VersionIni::LoadFile() |(06) Ini file found - Name: version.ini; Path: C:\TIA_TEMP_WINCC\InstData\HW_Collector\Media\version.ini
19:53:33| |VersionIni::LoadFile() |
19:53:33| |VersionIni::LoadFile() |(06) START validating config file
19:53:33|... |VersionIni::ValidateSection() |(06) Config file section key [IDENTIFICATION] -> 'DefaultLogFileName' is present but unknown to the config file definition.
19:53:33|. |VersionIni::LoadFile() |(06) END validating config file
19:53:33|.. |MsiEnvironment::OpenMsiDatabase() |(06) Function returns value: ERROR_OPEN_FAILED; Attempt to open file: 'C:\TIA_TEMP_WINCC\InstData\HW_Collector\Media\HWCN-HWCOL.msi'
19:53:33|.. |MsiEnvironment::OpenMsiDatabase() |(06) Attempting to open MSI file once more... 1
19:53:33|.. |MsiEnvironment::OpenMsiDatabase() |(06) Attempting to open MSI file once more... 2
19:53:33|.. |MsiEnvironment::OpenMsiDatabase() |(06) Max count of reopen attempts reached: 3. Giving up...
19:53:33|INFO1 |MsiEnvironment::AddProductByPath() |(06) Msi product was not initialized. Return value: ERROR_OPEN_FAILED
19:53:33|ERROR |EnvironmentAnalyser::Analyse() |(06) Exception - SetupMsiException Siemens.Automation.Setup.Core.SetupMsiException: MSI File initialization failed: ERROR_OPEN_FAILED
19:53:33|ERROR | ... continue line ... |Exception - at Siemens.Automation.Setup.Sia.Engine.Prod.SetupUnitFromBundle.InitializeMsi(MsiEnvironment msiEnviron)
19:53:33|ERROR | ... continue line ... |Exception - at Siemens.Automation.Setup.Sia.Engine.Environ.EnvironmentAnalyser.Analyse(DoWorkEventArgs e)
######## ---------- END SECTION --------------------------- ####################
ahmedsaidm
Post by ahmedsaidm »
i don't know what is the problem inside your copy i tested it over 6 PCs in two version of windows : windows 7 x64 and windows server 2008 R2 in the 6 PCs i face the same problem the setup will stop when the estimated time is 2min and if i end the setup and start the TIA during creating new project and selecting the PLC or HMI i face error restart or close ....in the 6 PCs i will try the update. (wow) (wow)
ahmedsaidm wrote:i don't know what is the problem inside your copy i tested it over 6 PCs in two version of windows : windows 7 x64 and windows server 2008 R2 in the 6 PCs i face the same problem the setup will stop when the estimated time is 2min and if i end the setup and start the TIA during creating new project and selecting the PLC or HMI i face error restart or close ....in the 6 PCs i will try the update. (wow) (wow)
Stuxnet or Flame ?
Need screencopy with error messages.
I tested this version over 6 PCs in 3 version of windows : windows XP/ windows 7 x32/x64 :D
ahmedsaidm
i was facing the problem in windows 7 x64 but after reinstall it's fixed but for windows server 2008 R2 i am still facing the above.
i left it for the whole night and in the morning i found the same remaining time. this actually happened in 4 pcs in the same time.
FYI all my windows copies are original. and when i stareted the Tia and just when i select the PLC model i got not responding and a message telling close or restart......any advice for that.
also you can see the below demonstration:
http://www.youtube.com/watch?v=hd6uoRCD ... e=youtu.be
kaa1979
Post by kaa1979 »
Try to turn off User Account Control (UAC), antivirus and firewall on an installation time.
ahmedsaidm wrote: i was facing the problem in windows 7 x64 but after reinstall it's fixed but for windows server 2008 R2 i am still facing the above.
1. Do you think that the two processors can run two incompatible work at same time ? :lol:
0. To buy the official version of the program - this will allow you to receive official support.
Russian wrote:Египтянене думают, что два процессора позволяют делать несовместимые работы одновременно - разрушать государство и при этом жить припеваючи. А потом удивляются - Почему туристы не едут к ним отдыхать ...
Для работы покупайте официальные версии программ - это позволит тебе получать официальную техническую поддержку.
ahmedsaidm
Re: [?]: Personal problems with TIA Portal
maybe the problem is due to using Server2008 R2 datacenter version.
i got a message at the beginning informing that this version is not officially supported.
I view in your video - Step7 work, in this time you install WinCC - this is your ERROR.
When you install Simatic all others programs need to close.
ahmedsaidm
no the problem is it stopped for 8 hours in 2 minutes remaining time. i tried to reinstall more than once but it give the same result in different 4 pcs. so i guess the problem is windows server 2008 R2 datacenter version is not supported.
Ilya
Post by Ilya »
ahmedsaidm wrote:no the problem is it stopped for 8 hours in 2 minutes remaining time. i tried to reinstall more than once but it give the same result in different 4 pcs. so i guess the problem is windows server 2008 R2 datacenter version is not supported.
+1
The same problem at Win 7 x64 :(
