Request: SIPROTEC DIGSI 4.84
nsr1
Post by nsr1 »
hello all members,
I need full dvd Siprotec Digsi 4.84
please if someone would be so kind, thanks
Digsi 4.83 viewtopic.php?f=1&t=9059
Schtiel
[LINK:] SIPROTEC DIGSI 4.85 UPDATE
Post by Schtiel »
DIGSI 4.85 update is available here. It can be installed over DIGSI 4.83.
DIGSI 4.85 includes the following changes:
1. 64-bit operating system support
2. Support of new Feeder Automation Controller 7SC80
3. Feeder Automation Sequence Editor (FASE)
4. Support of new Smart IED 7SJ686
5. Support of devices with multiple system interfaces
6. IEC 61850
6.1. In System Configurator, devices can be renamed without loosing configured static reports (CHDOC00032532).
6.2. Fixed sporadic problems when updating IEC 61850 station with third-party ICD (CHDOC00024520).
6.3. Consistent handling of IEC 61850 Interlocking options in DIGSI Configuration Matrix (CHDOC00032037).
7. Import and Export
7.1. Correct export of PROFIBUS DP system interface (CHDOC00032480)
7.2. Modbus system interface export works correctly (CHDOC00023976)
8. Canceled CFC changes are not transferred into device (CHDOC00030608)
9. IEC 60870-5-103
9.1. Fixed problems with 7SJ/SK devices and IEC 60870-5-103 (CHDOC00026078)
9.2. IEC 60870-5-103 address remains unchanged after download settings (CHDOC00036580)
10. Correct indication of sectionalizer (CHDOC00024675)
11. Correct feeder currents shown during bay out of service (CHDOC00024294)
12. Information about incompatible DIGSI versions is shown (CHDOC00028898)
13. User-defined symbols can be controlled in the control display (CHDOC00024032)
14. Start menu shows correct entries although DIGSI and SIMATIC are installed in parallel (CHDOC00039443)
15. All functions available after MLFB change (CHDOC00037752)
16. Show attributes of USB device (CHDOC00025017)
17. Connection with 7SJ80 works also via USB port (CHDOC00024415)
18. Display of distance zone graphic does not crash DIGSI (CHDOC00040336)
19. Improved compatibility of CFC data types (CHDOC00040585)
nsr1
Re: Request: SIPROTEC DIGSI 4.84
Post by nsr1 »
Would someone please kindly upload to another server DIGSI 4.83 download than Rapidshare, 30kb download to slow.
Thank you very much for your help.
nsr1 wrote:Would someone please kindly upload to another server DIGSI 4.83 download than Rapidshare, 30kb download to slow.
use Torrent with BIG speed
nsr1
Post by nsr1 »
thank you very much faster download now. (clap) (clap) (clap) (clap) (clap) (tyou)
