[?]: WinCC compatibility for migrating v5.1 project
krneki
Post by krneki »
I'm new to PLC's so I really need some basic advices.
I've installed "SIEMENS SIMATIC STEP 7 v5.5 SP1 + PLCSIM v5.4 SP5 (x32+x64)" and Step7 works fine (at least I think so :? ).
Now I also need WinCC, but I have no idea which version to install.
I think the newest one would be the best, but I also need to open a project which was created with version 5.1.
Will I able to do that if I use the newest version?
I have Windows 7 x64.
Thanks for help!
Info
Faq & Info
Faq & Info
Re: [?]: WinCC compatibility for migrating v5.1 project
Post by Info »
(sfaq) http://support.automation.siemens.com/W ... n/44029132
How do you migrate WinCC projects to new versions of WinCC from V4 to V7?
4 Migration from SIMATIC WinCC V5.1 to SIMATIC WinCC V6.0/V6.2
5 Migration from SIMATIC WinCC V6.x to SIMATIC WinCC V7.0
krneki
Post by krneki »
And which versions of WinCC are compatible with Windows 7 x64? If 5.1 runs fine, I don't see any major reasons to use newer version. Are there big differences between versions?
Rex2701
Post by Rex2701 »
krneki wrote:And which versions of WinCC are compatible with Windows 7 x64?
WinCC 7.0 with SP3 only.
krneki
Post by krneki »
So how can I convert 5.1 project to 7.0 SP3 with Windows 7 x64?
What about WinCC v11, is that one even newer?
Info
Faq & Info
Faq & Info
Post by Info »
