Dear All,
What Ethernet cable to use for programming and connecting with S7-300 Cpu with ethernet port when connecting directly with the CPU or not using a ethernet network switch? Is it a straight through or crossover cable?
Thanks in advance.
[?]: What Ethernet Cable to use for S7-300 CPU
Re: [?]: What Ethernet Cable to use for S7-300 CPU
Crossover is the answer, definetly.Peehel wrote:Dear All,
Thanks in advance.
With a crossover, even if there is a switch everything is fine. With a straight you can work only with switch or , without a switch, hope that the auto-switching firmware is working properly (pretty rare).
So use a crossover.
For your information the crossover is the dark white cable with green connectors (this is the default aspect).
suzhoumaduaoyun
Nomaly Siemens PLC is support both type of the ethernet cable ,it means straight and cross can be actomaticly check by siemens PLC.
