[?]: Archive Error During start up Win CE MP277
baba1511
Post by baba1511 »
Hello
Help highly needed
During start up our windows CE MP277 stops with the following error on checking alarm Archives,
error wrote:''Mess Archiv Check''
Error Cannot create tempfile: Unexpected error (32)
;;Prozesswerte [Archiv_Niveaukessel6.csv]''
Best regards
If we OK the last screen the following screen will come up.
Info
Faq & Info
Faq & Info
Re: [?]: Win CE MP277 Error
Post by Info »
(sfaq) http://support.automation.siemens.com/D ... n/20681208
Switching off operator panel with memory card slotted
In order to avoid possible loss of data, you must always close down the Runtime software before switching off the power supply.
For this you operate the control that is linked to the "Terminate_Runtime" function in your configuration. Wait until the Start menu is displayed and only then switch off the power supply. If you cut the power supply by mistake during running operation, the operator panel checks the memory card after restart and repairs any defective areas. A description of how to restore the file system of a memory card is available in the MP377 manual under "MP377, MP377 PRO (WinCC flexible) > Configure operating system > Change operator panel setting > Backing up Registry entries"
Automatic repair of the memory card can be enabled in the Control Panel under OP in the "Persistent Storage" tab.
baba1511
Re: [?]: Archive Error During start up Win CE MP277
Post by baba1511 »
This case is true, The Machine was powered down in error. Please what can I do to restart this machine now that we have installed a UPS.
''I am new to this '' I am a novice.
Thanks and forgive me for taking your time.
