[?+]: crack for Citect SCADA 7.20 SP3
jbdata
I need crack for Citect SCADA 7.20 SP3, Anyone?
giffgis
Re: Request: crack for Citect SCADA 7.20 SP3
Hi, don´t need crack because magic key exist.
https://rapidshare.com/files/1911178885/CitecScad.rar
1° Install .reg (double click)
2° Run Install.bat
3° Restart computer.
Note: must be installed the driver before apply patch
Work in Citect v6.0 and higher. Not work for Vijeo versions.
2° Run Install.bat
melin
If you want to use with other versions, you need to edit ACA3.reg and change the 41 value:
i. CitectSCADA (0xD341)
ii. Mitsubishi (0xD342)
iii. Nexa (0xD343)
iv. Vijeo (0xD361)
For Vijeo you need to change 41 with 61
Melin
iii. Nexa (0xD343)
iv. Vijeo (0xD361)
Melin
af.naderi
Thanks for your share,
I follow instructions and install patch.When i run project, all servers (I/O server, trend server and etc) run, but client stopped and don't run.
Note: First i use patch for CitectSCADA Ver. 7.2 SP3 and then change 41 value to 61 for VijeoCitect Ver. 7.2 SP1. In both software it doesn't work.
What 's the problem?
af.naderi
Hi every body,
I still have problem with this crack. You can view error report as follow:
ERROR.rar - 42 KB
Please help
ERROR.rar - 42 KB
Please help
abbasmech
I cant download from rapidshare any body can upload crack to another server
crunming
vijeo citect 7.2 sp2;after installed dongle,CiUSAFE check is ok,but when run demo project,the citect32.exe will stop!
AppName: citect32.exe AppVer: 7.20.2.63 ModName: msvcr90.dll
ModVer: 9.0.30729.4148 Offset: 0003fd97
anyone have Any suggestions~
thanks~
thanks~
djalmaz
In Vijeo Citect 7.20 SP3 this emulator works, CiUSAFE says that everything is OK with the key, but web client this key cann't find and the result error - not found license. Are there any solutions?В Vijeo Citect 7.20 SP3 этот эмулятор работает, CiUSAFE пишет, что с ключом все ок, но веб клиент ключа в упор не видит, выдает ошибку - не найдена лицензия. Есть варианты решения?
af.naderi
hi djalmaz,
I have still problem with emulator, but you say it works (but without web client). If it's true, tell us how we can use it?
What's your OS (SP and ...)? Which version of citect or Vijeo do you use? and any useful notes.
Please help. We need it.
djalmaz
Hi af.naderi, I use Win XP SP3, Vijeo Citect 7.20 SP3.
I use this ACA3.reg:
If you need Citect then change 61 with 41 in this text.
And then use the standard procedure for emulating the key as described above:
1. Install .reg (double click)
2. Run Install.bat
3. Restart computer.
Vijeo Citect are working normal, Citect I didn`t test
ACA3.reg
Show
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\MultiKey\Dumps\0000ACA3]
"DongleType"=dword:00000003
"Name"="Sentinel CITECT"
"Type"=dword:00000000
"CellType"=hex:01,01,03,03,03,03,03,03,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
"sntMemory"=hex:54,32,A3,AC,EE,0C,00,00,08,00,00,00,00,00,00,00,\
61,D3,FE,FF,FF,FF,10,10,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,FF,FF,FF,FF,\
FF,FF,00,00,00,00,00,00,00,00,FF,FF,FF,FF,48,00,\
22,EE,33,EE,01,01,01,01,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,29,0F,00,00,\
00,00,00,00,00,00,00,00,FA,FF,FF,FF,01,00,FF,00,\
00,00,00,00,01,00,00,00,00,00,00,00,AA,AA,00,00
2. Run Install.bat
blackhawk
Thanks djalmaz! I confirm your registry work for both Vijeo Citect and CitectSCADA 7.2 SP3 (change 61 to 41)
Base on your registry, I will upload my change to activate web server license.
Update, web server license:
ACA3_720_web.reg
Show
41,D3,FE,FF,FF,FF,10,10,00,00,00,00,00,00,00,00,\
FF,FF,00,00,00,00,00,00,00,00,20,00,20,00,48,00,\
djalmaz
Thank's a lot,blackhawk, web client works with these settings, I will continue my experiments with web deployment.
af.naderi
oh my god, it's working well. Client doesn't crash.
Thanks a lot blackhawk. Finally, I can test networking in Citect.
Thanks Thanks Thanks
huda2112
Can you show me where can I get the driver for USB key?
Sorry for my question but I tried to install some driver but it's still looking for its driver.
Please help me.
Thank you very much
Please help me.
Thank you very much
djalmaz
Re: [?+]: crack for Citect SCADA 7.20 SP3
Hello, guys. My troubles with web deployment is not over. On the local machine where the server IO works, web client works fine. But if you try to run a Web client from another machine in the network - the result is the same - not found a security key ( the Web client can not establish connection with IO Server). Settings are all done by the description to the web deployment.Can anyone test the web client? af.naderi, blackhawk test please,I cannt understand what the problem is. Thanks!
Understood what it was. In IO servers, trends server and other servers you must specify the network address of local machine where IO server works. It's simple ...
This key is working fine. Thanks to all!
AngelGomez
Hi giffgis Can you Please update the link of Citect SCADA V7.20 because it says that it isn't there anymore
Appreciate you help on this!!!
giffgis
panicni
Hello.
I have tried your crack but I have the same problem as crunming .
I have checked if I have CitectSCADA (0xD341) value in reg file. It is OK.
Even if I look at CITECT KEY licenses are OK.
If I look what happened I got this info:
citect SCADA 7.20[2];after installed dongle,CiUSAFE check is ok,but when run demo project,the citect32.exe will stop!
AppName: citect32.exe AppVer: 7.20.0.598 ModName: msvcr90.dll
Do you have somekind of solution?
skitty
Are u trying a reg key from blackhawk?
panicni
Hello.
I have entered the reg file user: blackhawk has submited.
Now everything works..
Great...
Thanks again.
I have another question regarding Citect Nexa 6.1.
I'm using Citect as OPC server. In version Citect SCADA 7.2 everything works. I connect to scada with DOPC client. I can read / write values to all variables / tags.
But if I try to conect to Citect 6.1 I got error.
OPC client (DOPC) can't connect to Citect OPC server - I got error.
Does some of you try something similar?
Great...
Thanks again.
koroosh_kabir
i download scada 7.3
and use of crack (CitecScad.rar) and also new reg file.
but after runing the program, at license menu, i see DEMO item and it's not any installed dongle or license.
i need to install vijeo and scada that work well.
please help me.
email:ms98121@yahoo.com
thanks
please help me.
thanks
panicni
Hello.
I tried to instal this crack to windows 7 64-bit.
But I can't instal the dongle driver.
The instalation just ends.
On Win7 32-bit everything works fantastic.
Does enyone have an idea how to install dongle on win7 64-bit?
Thanks.
Thanks.
mirzaei
Dear Friends
i test the magic key in Citect7.3 but it didn't work.
would you plz help me on this ?
tnx in advance
tnx in advance
ee6687
hi all
i used the crack, its fine and work but, just for some minutes. i'm try use vijeo citect 7.2 for backnet/ip, it work for some minutes fine, but about 5 minutes after running the project, alarm says the io device is offline, and the project stpos working. i used "citect scada 7.0" and have no problem (i used another crack for that.).
i checked the license and it shows in "Demo".
how can i fix this problems?
i need it.
Gieske
Somebody already has found a solution for Citect7.3?
kresekjoy
And maybe for Vijeo Citect 7.4?
Gieske
Did anyone already manage to run the magickey on Win7 64Bit???
monty_burns_007
any dump yet for 7.4 ?
silviudima
Could someone provide a new link for crack ? The previous links are no longer available. Thanks.
socket_a
Кт оне будь перезалейти пожалуйста заранее спасибо
panicni
Is there reg file for V7.40 and V7.50?
Imanu
Yes.Gieske wrote:Did anyone already manage to run the magickey on Win7 64Bit???
Download the driver here: https://drive.google.com/file/d/0Bwv-LA ... 1neUU/edit
There is a 64bit version.
Install the registry entry and the driver.
Remember to turn off digitaly signed drivers.
It worked for me on w7 professional 64bit
Thanks all. This magic key is great!!!!!!!
dadi
pointgrey
magic key for 7.4 please
aherdian
I need crack for Citect SCADA 7.20 SP3, Anyone can help me?
The link is not working anymore
baran
Hi everybody.
I try to download magic key but all of them expired.
Anybody has a magic key and registry file?
Thanks.
Thanks.
adriano225
Please! Help! I need crack for Citect SCADA 7.40!
alism
Hi
Please upload this file on other palace.
All of the link in this post dosent work
djalmaz
For OMAR_ZAR: follow the link to the topic Citect 2016, the key is suitable for 7.20, the link is working, the order of installation is described.
viewtopic.php?f=14&t=25021#p79945
KaskadSD
Good day!
How activate VijeoCitect 7.20 or higher on x86 OS?
Because multikey.inf for installing virtual USB multikey 64bit driver. How can I adaptive it to x86 system?
Devcon for x86 I downloaded already.
https://drive.google.com/open?id=102T9o ... LgJk8gm6nc
