hello
i was trying to connect to the plc to upload the program but through pl7pro from my pc via tsxpcx1031 cable but when i pressed connect a message appeared and it said : Unable to establish the physical link with the PLC address SYS via driver UNTLW01.
i checked the COM port,the cable and the driver ,they are well installed so i changed the plc 3721 whith a nother one tsx3710 and same problem .
itaught may be it was the cable i changed it but same problem .
help please ?
communication problem with TSX3721??
Re: communication problem with TSX3721??
Uninstall the old Unitelway-driver and install Unitelway-driver with the Driver Pack.
Удалите старый Unitelway-драйвер и установите драйвер из Драйвер Пака.
did that,still not workingSerge_n wrote:Uninstall the old Unitelway-driver and install Unitelway-driver with the Driver Pack.
