I have one HMI TP277 8" with the CPU226CN. Want to integrate another HMI TP277 8" with the same Runtime program running in the 1st TP panel.
That is one CPU and identical parallel HMI with same runtime program. I have the TP277 8" Prosave Backup program.
if i download the Prosave Backup into the 2nd TP277 panel and connect the communication cable with it whether it will work(as Address will be same for two CPU)?
Or i need to give another address into the 2nd TP panel?
Please give suggestion.
Counter
[?]: Integrating two TP277 with one CPU226CN
counterreset
