Hi all
I would like to understand at the first if I have pcs7 is it possible to add instrument ( communicate by PA ) in hardware configuration by standard profile or i have to use PCS7 PROFILE CATALOG .
if any one has a quick start guide to illustrate for me the steps ( for using PA instrument which connected to IM175 AND TO IM153-2 ) ?
THANKS IN ADVANCE
MAHER
[?]: starting by PCS7 and using PA instrument
maher
Re: [?]: starting by PCS7 and using PA instrument
you can use standart & pcs catalog too
pcs catalog it`s filtered standart for pcs
