dear all,
i present myself, my english is poor and i don't really know something about CAD.
maybe someone can help me:
I have a electrical diagram with the .z13 extension.
i try to open it with winzip and inside i found a an Eplan4 directory.
I try to open to open this .z13 file with eplan P8 but it's not possible (  with project Tab choose E-Plan5/FluidPlan Data, then Project).
In fact i can't select my z13 file ( 'do not enter' sign appear just in front of the z13 file).
How can i open this .Z13 file ?
thank's.
						Eplan4 Z13 files
				AntexL
Re: Eplan4 Z13 files
You can try open it by any Zip archivator.
				sadefa
I think you should use Eplan 5 in order to open this project. Store it as Eplan 5  project and after taht convert it with P8 to the latest version.
				dsekulic
If You use Eplan P8 than You can use import Eplan5 project. Go to Project->Eplan5/fluidPlan data import->Project...
Press on Surce dots and in popup check Data Backup (z13,...). Afterward You select Your z13 file
regards
regards
