[LINK]: GP-Pro EX Ver. 3.01, 3.10, 3.50
nam2012
GP-Pro EX Ver. 3.01.100 or earlier
[Disk 1 Description]
- GP-Pro EX Ver. 3.0
- Transfer Tool
- Pass Through
- Pro-face Converter
http://letitbit.net/download/07329.0c27 ... 1.exe.html
[Disk 2 Description]
- WinGP
- Movie Converter
- GP-Viewer EX
- Camera-Viewer EX
- Data Copy Tool
- GP Remote Printer Server
http://letitbit.net/download/84870.8548 ... 2.exe.html
[Installation of Pro-face Converter]
To install Pro-face Converter, please follow the procedure below.
Failure to follow the procedure will lead to an installation failure and display the message, "Please insert CD of Pro EX Editor in the CD drive."
Double-click the GPPROEX301100D1.exe file.
Open the GPPROEX301100D1 folder that is created in the same location as the EXE file.
Copy the file, ABS.sys, from the folder to the root folder (C:\).
Double-click ProEX_Setup.exe to start the installer, and select Pro-face Converter.
After installation, delete the ABS.sys file.
S/N: 41274421374
Key-code: 1271-8497-9558
or
S/N: 41274420064
Key-code:: 1581-7685-6098
or
S/N:30507530020
CD KEY:4532-9332-8439
or
S/N : 30507530010
KEY CODE : 4632-3046-8059
or
S/N:03019010023
keycode:5118-2809-1609
OR
http://www.ziddu.com/downloadlink/12648091/Serial.rar
- Transfer Tool
- Pass Through
- WinGP
- Movie Converter
- GP-Viewer EX
- Camera-Viewer EX
- Data Copy Tool
S/N: 41274421374
or
S/N: 41274420064
or
S/N:30507530020
or
S/N : 30507530010
or
S/N:03019010023
OR
vlad2006gr
Re: GP-Pro EX Ver. 3.01.100 full
From the site http://www.pro-face.com/otasuke.
Registration is required (free).
http://www.pro-face.com/otasuke/files/t ... 1100D1.exe
http://www.pro-face.com/otasuke/files/t ... 1100D2.exe
This is from the old version does not work:
nam2012 wrote:
S/N: 41274421374
or
S/N: 41274420064
or
S/N:30507530020
or
S/N : 30507530010
or
S/N:03019010023
OR
vlad2006gr
For version 3.0 and 3.01.100: the installation click the checkbox of "Not Input Serial / Key Code (Limited Edition)", and then click "Next"
After installation, run the reg file.
We have to check.
Good luck!
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.0}]
"KeyCode"="1111-5588-8888"
"SerialCode"="35550610212"
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual\{EE304098-FA06-431B-8C5D-F6CA2A5F9E8C}]
"en"="300000"
Good luck!
Tombo999
I'm the new
Do you have also a key or a patch for GP-Pro EX 3.1?
Thanks a lot
I'm the new
Thanks a lot
ag-ias
The method above also works for version 3.1
kiyo
TEST PASS 100%!!
CONFIRM !!!
CONFIRM !!!
El_Guille
Version 3.10.000
http://download.pro-face.com/download// ... 0000D1.exe
http://download.pro-face.com/download// ... 0000D2.exe
The registry method above didn't work for 3.1
You must use this one (same as vlad2006gr, but with {GP-Pro EX 3.1} )
Thanks vlad2006gr !!!!
Version 3.10.000
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.1}]
"en"="300000"
GWEN
WinGP trial is still three hours!
Try to test the replacement rootFrame.dll directory Pro-face\WinGP\
No need keys, not trial
http://ulozto.cz/xTZoeswJ/rootframe-zip-
solcar1972
First I tried to install on windows 7 ultimate 64, but did not work.
Then I installed on an XP virtual mode with good results
Thank you for sharing
Best regards
Solcar
Best regards
Solcar
powerbrut
GWEN wrote:GP-Pro EX Ver. 3.01.100 full
No need keys, not trialCode: Select all
Hellò all, please need WINGP activation. Link not good, please resend link.
Tanks all.
vlad2006gr
powerbrut wrote:
Relink on rapidshare.com
https://www.rapidshare.com/files/249340 ... tFrame.zip
Good luck!
Link is good!Hellò all, please need WINGP activation. Link not good, please resend link.
Good luck!
sonia01710
Could anyone please help to find the registry file to edit. I could not find the reg file on run > regedit > HKEY_LOCAL_MACHINE > SOFTWARE. Please give me the details procedure to edit the reg.
Thanks in advance.
Thanks in advance.
vlad2006gr
GP-Pro EX Ver. 3.50.000
http://www.hmisource.com/otasuke/files/ ... 00_PFA.exe
1.2 Gb
Good luck!
1.2 Gb
Spoiler
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.5}]
"ValidateValue"="36"
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual\{C47AFC40-E13A-413A-9D60-F487766CC78A}]
"en"="350000"
Spoiler
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.5}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Manual]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Manual\{C47AFC40-E13A-413A-9D60-F487766CC78A}]
"en"="350000"-
shl235
GWEN
Re: [LINK]: GP-Pro EX Ver. 3.01, 3.10, 3.50
WinGP 4.03 remove trial is still three hours!
http://ulozto.cz/xXnFDir9/rootframe-4-3-zipRegister GP-Pro EX version 4.x - 64B Win 7
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 4.0}]
psgama
To ensure the DLL File does not have errors for WinGp Version 4.0
Make Backup Copy of all DLL
Windows 7 Hex edits
For the RootFrame.dll Found in C:\Pro-face\WinGP & C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\4000Series
Hex Edit at File Offset 64FB from 0F 85 80 F8 FF FF to E9 81 F8 FF FF 90
Hex Edit at File Offset 7434 From 75 6D 8B 86 7C 16 to EB 6D 8B 86 7C 16
For the RootFrame.dll Found in C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\GP410X & C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\3000Series
Hexedit at File Offset 572A from 75 62 8B 96 44 16 to EB 62 8B 96 44 16
Hexedit at File Offset C1DB From 0F 84 CE 00 00 00 to E9 81 CE 00 00 90
Windows 7 Hex edits
manutchai
thank you very much every body for this share.
Manutchai S.
Manutchai S.
rdoman2
rdoman2
Anyone know
serial
Keycode
for Ver 4.03 ?
serial
Keycode
for Ver 4.03 ?
amir abdelaziz
please can any one help me to activate GP-Viewer EX v3.1
when i view my pro-face hmi i found that GP-Viewer EX v3.1 work as atrail
GP-Pro EX Ver. 3.01 is activated
srithep
Thank you,
I can install GP-Pro Ex Ver 3. it full.
R mind
Hellò, please I need WINGP activation for GP-PRO-EX ver 4.09
please resend link :
R mind
@vlad2006grR mind wrote: Sat Mar 26, 2022 11:18 am Hellò, please I need WINGP activation for GP-PRO-EX ver 4.09
