Hi. Need your help...
When I try to download data (make backup) from e1022,terminal make an error.
It reboot and i have a transmission error.
At the start of downloading,everithing look normal. Data transmits to PC,but when terminal send DRV CONF ,it reboot thenself,and communication shut down.
I use E 1022
E Designer 7
CAB 30
After that I try to send new project from PC to terminal,and it works good..
help me,please
[?]: Mitsubishi terminal E1022
Re: [?]: Mitsubishi terminal E1022
hi sramo3
try to use designer 6 with updates
good luck
good luck
E designer 6 don´t support E 1000 terminals...
still nothing....
what software have you?in the document is written, how to connect and which program to use.
http://forums.mrplc.com/index.php?s=382 ... opic=22577
use of another adapter.for example moxa uport I1150.the reason for the adapter.
maybe baudrate is to high ?
