Hello everyone
I installed PCS7 v7.1 then installed Simatic_EKB and i did a mistake by installing all RC keys.
Then i discovered later that i must install only one key
SO Please i want to know how to remove these key to reinstall only one RC key?
Thanks in advance
[?]: How to remove keys ?
Re: [?]: How to remove keys ?
Press Help button
or
http://support.automation.siemens.com/W ... n/24200966
But today it not work Internal Server Error - Read
or use TotalCommander
or use ALM and USB memory stick => transfer keys from C:\ to memory stick:\
or
Procedure for deleting a Trial License
In the Explorer you mark the "AX NF ZZ" directory on your hard disk or on drive "C", so that the file names of the licenses are displayed in the right window of the Explorer.
If the "AX NF ZZ" directory or the files in that directory are not visible, then open the dialog "Tools > Folder options..." and select the "View" tab:
· Here you deactivate the option "Hide protected operating files (Recommended)" and
· Activate the option "Show hidden files and folders".
Then click on the "Apply" button and acknowledge with "OK".
Fig. 02
The "AX NF ZZ" directory is then displayed in the Explorer.
4 Mark the Trial License found in the "AX NF ZZ" directory and right-click. Then select "Delete" in the pop-up menu that opens. After deletion the message described above will no longer appear.
