Hello
I have OP7 which installed in the machine …
I was making backup of the program from HMI by '' Pro Save ''…
So can I immigrate that program by using WinCC flexible 2008 SP2 in order to download that program in new HMI OP77A
Please advise….
[?]: Is possible to migrate backup file from OP7 to OP77A ?
Re: [?]: Is possible to migrate backup file from OP7 to OP77
No.
Backup file is binary file - is not project. It impossible open with Flexible
Dear DiVan
Thank u for your prompt reply...
Is there other salutation....????
There is possibility to know the tags list in order to build another, new project with the same PLC meaning...as you already knew about that. Sorry, I forgot to send you that tool.
Here it is - http://plcforum.uz.ua//D ... roSave.exe
or use search here in forum to take a look at discussion there...
