How to communication Zelio to Visual Basic?
Fence
Hai.....All..
use protocol modbus.
Please help me.
Tank.
Please help me.
Tank.
pupena_san
Re: How to communication Zelio to Visual Basic?
Modbus RTU or Modbus TCP?
Fence
I use modbus TCP?
pupena_san
If use VB6 (VB5),
there are various variants:
1) VB6<->ActiveX WinSOCK<->ModbusTCP on Zelio
2) VB6<->other OLE Automation librarys Winsock TCP/IP <->ModbusTCP on Zelio
3) VB<-> OPC with Modbus TCP Client <-> ModbusTCP on Zelio
pupena_san
Simple example: read holding registers
1) place ActiveX Winsock with name Winsock1 to Form
2) place CommandButton to Form
VB6<->MS Winsock ActiveX Control<->Modbus TCP on PLC
Excuse for my English
Dim Reg(1 To 10) As Integer ' Values of Variables
Private Sub CloseSocket()
Winsock1.Close 'Close Socket
End Sub
Private Sub ConnectSocket() 'Connect to MODBUS
Winsock1.Protocol = sckTCPProtocol 'select ТСР protocol
Winsock1.Connect "192.168.9.17", 502 'specify ІР and TCPport=502 (Modbus Server)
End SubCode: Select all
Private Sub CommandButton3_Click()
ReadRegisters 0, 5 ' Read 5 Registers from 0
Sub ReadRegisters(StartAddr As Integer, CountAddr As Integer) ' My function for Read Registers - compose and send message
Dim a(1 To 12) As Byte 'bytes string for Modbus Message
If Winsock1.State = sckConnected Then 'if status WinSock is connected
a(6) = 6 'counter bytes
a(8) = 3 'function = 3 (Read holding registers)
a(9) = StartAddr \ 256 'Adsress of first Register - HI
a(10) = StartAddr Mod 256 'Address of first Register - LO
a(11) = CountAddr \ 256 'Number(Quantity) Registers
Winsock1.SendData a 'send Message
End If
Private Sub Winsock1_DataArrival(ByVal bytesTotal As Long) ' Responce Message
Dim a As Variant, LoInd As Integer, i As Integer, j As Integer
Winsock1.GetData a, , bytesTotal 'get message from buffer
LoInd = LBound(a) 'length MEssage of bytes
If a(7 + LoInd) = 3 Then 'if function equal 3 (Read holding registers)
For i = 1 To a(8 + LoInd) \ 2 'for each registers
j = 9 + (i - 1) * 2 'number bytes in array for each (i) registers
If (a(j) And &H80) > 0 Then 'if value negative (hi bit=true)
a(j) = a(j) And &H7F 'set hi bit=false
Reg(i) = a(j) * 256 + a(j + 1) - 32768 'calculate with sign '
Else
Reg(i) = a(j) * 256 + a(j + 1) ' calculate without sign
End If
Next
End If
End SubExcuse for my English
Fence
Can you share to me sample program VB and Zelio?
Tank.
Tank.
pupena_san
1) In the top example there are bags
Add code for initialize Connection, for Example:
In sub ReadRegisters Add code
Example in VBA Excel:
https://sites.google.com/site/fieldbusb ... ects=0&d=1
2) For ZelioLogic address registers and functions will be others. For Example Holding Registers 32-35 - DATE/TIME... registers. Please read Help for information of Modbus Mapping in Zelio.
Private Sub UserForm_Initialize()
ConnectSocket
a(12)=CountAddr Mod 256
Tehnik55
pupena_san, здравствуйте.
У меня к Вам вопросик:
Имеется контроллер ADAM6051, необходимо считывать с него состояния цифровых входов. Допустим с адресом 00008. Это я делаю с помощью VB6.
К нему я законектился:
А дальше как считывать регистры??? Поясните???
Я выше видел ваш код с пояснениями но по англ не очень понимаю...
заранее спасибо...
Connection Script
Show
Private Sub Command1_Click()
Dim StartTime
If (Winsock1.State <> sckClosed) Then
Winsock1.Close
End If
Winsock1.Connect "10.61.187.252", 502
StartTime = Timer
Do While ((Timer < StartTime + 2) And (Winsock1.State <> 7))
DoEvents
Loop
If (Winsock1.State <> sckConnecting) Then
Text1.Text = "Connected"
Text1.BackColor = &HFF00&
Else
Text1.Text = "Can't connect to "
End If
End Sub
Private Sub Command2_Click()
Winsock1.Close
End If
Do While (Winsock1.State <> sckClosed)
DoEvents
Loop
Text1.Text = "Disconnected"
End SubЯ выше видел ваш код с пояснениями но по англ не очень понимаю...
заранее спасибо...
pupena_san
С функционированием протокола MODBUS Вы знакомы?
Если 00008 это Coils 8, то нужно вместо функции чтения Holding Registers (03) использовать функцию чтение Coils (01), тоесть заполнить массив a другими числами.
Tehnik55
Если честно, то совсем плохо.
Я так понял 00008, т.е. 8 ModBus адрес?!
Кстати в описании на ADAM6051 я на картинке еще увидел напротив дискретного входа на кот у меня сидит датчик, вот такое 40015~40016.
Думаю 4 откидываем и получаем 15 и 16, это и есть младший и старший адреса регистра???!!!
Как правильно заполнить массив а если буду все таки использовать ModBus адрес???
И как соответственно потом вытащить что у меня будет на дискретного входе (0 или 1)???
Благодарен что откликнулись....
pupena_san
Сначала познакомьтесь с азами протокола Modbus, можно тут, можно тут, о особенностях MODBUS/TCP можно тут, тут (также пример на русском) или в оригинале на http://modbus.org/. Когда прийдет понимание сути работы протокола, тогда можно за конкретику браться.
Tehnik55
Ну про уровни OSI я вроде норм ознакомлен, а про ModBus конкретно ознакомлюсь.
Одним глазом пробежался по ссылкам хороший материал, только не увидел что значит каждый байт в массиве??! Как прочту все внимательно появится вопросики так что отпишусь позже....
Tehnik55
Спасибо большое за предоставленную информацию. Теперь понятно про 4-ре зоны (области) данных (переменных).
Действительно у меня Coils (начиная с 00001), или область дискретных выходов (выходных битов).
Что касается запроса:
- Код функции: 01 'Чтение Coils
- Адрес начального бита (HI) = 0
- Адрес начального бита (LO) = 8 ' Это если мне нужен дискретный выход 00008 - 8 hex
- Количество бит (HI) = 0
- Количество бит (LO) = 4 ' Это если мне нужны значения еще 4 последующих битов
Теперь это же в VB6:
Ответ контроллера должен быть таким (при правильном ответе):
- Код функции = 01
- Счетчик байт = 1 'это в том случае если я анализирую 4 дискретных выхода, значения кот уместятся в одном байте
- Значения битов (первые
Ответ контроллера в VB6:
Посмотрите пожалуйста может где не прав, если несложно поправьте???
Вот что-то с ответом, а точнее с выводом на TextBox в VB6 сомневаюсь правильно ли???
a(?) = 1
a(?) = 0 \ 256
a(?) = 8 Mod 256
a(?) = 0 \ 256
a(?) = 4 Mod 256
End If
End Sub- Код функции = 01
Dim a As Variant
Text1.Text = a ' чтобы вывести ответ котроллера
ReadRegisters 8, 4 ' считать значения 4 дискретных входа начиная с 00008
End SubВот что-то с ответом, а точнее с выводом на TextBox в VB6 сомневаюсь правильно ли???
pupena_san
Тут были?
Назовите функцию лучше ReadCoils, а то потом путаться будете.
При ответе в текстовом боксе будете видеть кракозябрики.
Думаю что при обращении в функции к 8-му биту Вы обратитесь к 000009.
Проверять лучше сразу на оборудовании. Перед тем как проверить программу на VB советую проверить связь на тестовых программах типа ModbusPoll http://www.modbustools.com/ или подобных. Тогда многие ньюансы будут решены уже на том уровне.
Но это надо уточнить в модели устройства.Перед тем как составить запрос, следует отметить один важный момент - регистры (и другие ячейки) в модели MBAP нумеруются с 1-го, а в запросе с 0-го. Это одна из самых запутанных историй, из за которых "танцуют с бубнами" не только новички![]()
Tehnik55
Там был но что то не обратил внимание.
Вообще я подключался к устройству с помощью ModBus OPC Server. И если допустим мне нужно подключиться к дискр выходу DI7 я набирал 00008, в принципе у меня в описании написаны про адреса дискр выходов!!!
Теперь разобрался:
А что касается текстового бокса, могу я ваш код использовать, чтобы кракозябр не было:
Только не увидел куда вы водите ответ от контроллера???
Теперь разобрался:
a(1)=0
a(2)=0
a(3)=0
a(4)=0
a(5)=0
a(6)=6 ' зависит от кол-во последующих байт
a(7)=1 ' адрес устройства, взял 1 п.ч. когда настраивал ModBus OPC Server, то брал адрес устройства=1
a(8)=1 ' код функции ReadCoils
a(9)=0\256
a(10)=8 mod 256
a(9)=0\256
a(10)=4 mod 256
'ВЕРНО???Code: Select all
Else
End If
Next
End If-
pupena_san
Числа
a(9)=0
a(10)=8
a(11)=0 (у Вас опечатка)
a(12)=4 (у Вас опечатка)
можно вводить в массив a неспосредственно. В исходном коде предвидена возможность вводить значения адрессов >255, а в Вашем случае байты можно вносить вручную в HI и LO.
В ответе вы ловите биты а не регистры. При правильном ответе Вы должны получить набор битов по 8 штук. Разложите 10-й байт входящего массива (a(10 + LoInd)) побитно или выведите в текстбокс весь байт.
a(9)=0
a(10)=8
Tehnik55
Dim a As Variant
Text3.Text = a(10)
End Sub-
Tehnik55
Решил посмотреть вообще что-нибудь приходит отнего:
В окне пусто. Неужели он не отвечает??? Вот дела?!
Dim stra As String
Winsock1.GetData stra 'get message from buffer
MsgBox stra
End SubИ так еще раз вот полный код:
Show
Option Explicit
Dim StartTime
Winsock1.Close
End If
StartTime = Timer
DoEvents
Loop
Else
End If
End Sub
Winsock1.Close
End If
DoEvents
Loop
End Sub
Sub ReadCoils() ' My function for Read Registers - compose and send message
a(1) = 0
a(2) = 0
a(3) = 0
a(4) = 0
a(5) = 0
a(6) = 6 ' çàâèñèò îò êîë-âî ïîñëåäóþùèõ áàéò
a(7) = 1 ' àäðåñ óñòðîéñòâà, âçÿë 1 ï.÷. êîãäà íàñòðàèâàë ModBus OPC Server, òî áðàë àäðåñ óñòðîéñòâà=1
a(8) = 1 ' êîä ôóíêöèè ReadCoils
a(9) = 0
a(10) = 8
a(11) = 0
a(12) = 4
End If
End Sub
Private Sub Command3_Click()
ReadCoils ' ñ÷èòàòü çíà÷åíèÿ 4 äèñêðåòíûõ âõîäà íà÷èíàÿ ñ 00008
End Sub
Dim stra As String
MsgBox stra ' ÷òîáû âûâåñòè îòâåò êîòðîëëåðà
End Sub
pupena_san
Получайте переменную Variant а не String.
Я не знаю, почему у Вас UnitID=1, обычно он=0 или 255. UnitID предназначен для адреса Slave, который подключен к шлюзу Modbus/TCP<->Modbus RTU с заданным IP.
Возьмите для начала за базу мой код, попробуйте прочитать какие-то регистры а потом экспереминтируйте.
Tehnik55
Dim stra As VariantРешил попробовать а(7) = 0, то вообще никакое окно не вылазит, я так полагаю что просто не может прочитать п.ч. UnitID неправильно указан.
Как только а(7) = 1, то окно вылазит но ничего нет.
Мне кажется это все равно показатель что правильно выбран UnitID=1 или я ошибаюсь???
pupena_san
Попробуйте так
LoInd = LBound(a)
msgbox a(10 + LoInd)-
Tehnik55
Щас попробую
Вот еще решил узнать что нибудь вообще идет от контроллера и поставил Stop (останова) после Winsock1.GetData a, , bytesTotal.
Затем зашел в Locals в меню View и увидел что ответы идут, а именно:
a(0)=0
a(1)=0
a(2)=0
a(3)=0
a(4)=0
a(5)=4
a(6)=1
a(7)=1
a(8)=1
a(9)=63
Пытаюсь теперь все интерпретировать???!!!
a(0)=0
a(1)=0
a(2)=0
a(3)=0
a(4)=0
a(5)=4
a(6)=1
a(7)=1
a(8)=1
a(9)=63
pupena_san
TransactionID
a(0)=0
a(1)=0Code: Select all
ProtocolID
a(2)=0
a(3)=0Code: Select all
Length
a(4)=0
a(5)=4Code: Select all
UnitID
a(6)=1Code: Select all
FUNCTIION
a(7)=1Code: Select all
Счетчик
a(8)=1Code: Select all
биты в Байте
a(9)=63 - в десятичной системе
в двоичной системе 00111111-
Tehnik55
Вот так сделал
f
Так все норм.
Ктати так тоже норм Text3.Text = Val(a(9))
LoInd = LBound(a)
If a(9 + LoInd) = 126 Then
Text3.Text = "На выходе 1"
Else: Text3.Text = "На выходе 0"
End IТак все норм.
Tehnik55
Да, да понял, не успел отписаться, я в описании прочитал.
Переводить я умею:
Только в описании не написано: что каждый бит значит???
Предполагаю что каждый бит отвечает за свой вход. а те кот не опрашиваются 0-ми ("В сообщении-ответе каждое значение переменной передается одним битом, то есть в одном байте пакуется статус 8 битов переменных. Если количество их не кратно восьми, остальные биты в байте заполняются нулями.") заполняются!!
Переводить я умею:
Tehnik55
Все разобрался, кто и что там!!!
Осталось чтобы прога опрашивала постоянно контроллер, а не по команде с кнопки.
Ну хотя бы раз в секунду!!!
pupena_san
Таймер на форму и вперёд. Но это уже на форуме по VB спрашивайте.
Tehnik55
С таймером я сам в состоянии справиться.
Другой вопрос вот мы анализируем 10 байт. Там 8 бит и каждый можно сказать отвечает за свой выход. Это если их 8 выходов. А если 12, то остальные значения будут в 11 байте отображаться???!!! Так в описании написано. А в ответе 11 байт не приходит!?
pupena_san
В запросе надо попросить. Вы же просите 4-ре, приходит наверное 8-мь, попросите 16-ть.
Tehnik55
Все верно, если запрашивать больше 8, то приходит 11 байт и.т.д.
Tehnik55
Спасибо, Вам. Я думаю тема разобрана хорошо и иссякла себя!!!
Если не секрет, а вы с какими контроллерами работали, чтобы на будущее знать!!!???
pupena_san
Тут люди работают с разными контроллерами. Так что задавайте вопросы в новых ветвях, думаю Вам ответят.Tehnik55 wrote:Если не секрет, а вы с какими контроллерами работали, чтобы на будущее знать!!!???
Tehnik55
Проблемка возникла. Может тоже сталкивались?!
На одном буке (W7) зпускаю прогу все норм работает. Делаю EXE все пашет.
Притаскиваю тот же EXE на другой комп (XP). Выкатывает ошибку: Component 'MSWINSCK.ocx' or one
of its dependencies not correctly registered: a file is missing or invalid. Что то типа компонент не правильно зарегистрирован...
Попробовал принести сам код и запустить, все хорошо. Как делаю EXE снова таже ошибка!!!
Может дело в том, что разные системы(W7 продвинутая)???!!!
Подскажите как решить эту проблемку!!!???
Кстате потом на Wista пытался EXE запустить, снова ошибка...
pupena_san
Это к гуру по VB. Очевидно библиотека с ActiveX WinSock на компе не зарегистрирована. Где-то уже о подобной проблеме на форуме проскакивало, либо на этом либо на http://iadt.siemens.ru/forum/. По моему библиотека ставится вместе с VisualStudio. Попробуйте перенести на комп библиотеку в system32 и с командной строки запустить
может так получится.
regsvr32 название_файла_с_полным_путём
