Hi all,
I need to open one small window showing some fields when I press one button.
But I do not see the way in wincc flexible, I can open an image but no a faceplate. And the images are not resizable, so they are too big for my application.
The idea is to press a button, open the faceplate, set the fields wich are inside, and with another button also inside the faceplate, close it.
Any idea?
[?]: How to open faceplate with a button
Scarch
Re: [?]: How to open faceplate with a button
it`s not wincc it`s flex ! you need place faceplate on your screen & use show/hide
for how to ,check this link http://support.automation.siemens.com/W ... n/36435784
