Hi....
I'm looking for example program for using PID controller function in PLC S7-300 in order to control the level of the water in the storage tank ...
Thank u...
[?]: Simatic STEP7 PID Controller example ?
Re: [?]: Simatic STEP7 PID Controller example ?
Take a look following link
Where can I find an example of level control that can be parameterized via SIMATIC Standard PID Control?
http://support.automation.siemens.com/W ... en/8846287
regards
regards
Hi dsekulic
Thank u for ur reply...
can i use standard PID Control Tool software V5.2 + SP2 for my application ...
Thank u for your time...
Of course You can use PID Control Tool software V5.2 + SP2. There is no any restrictions.
regards
regards
Dear dsekulic
Hello
Hoping you are ok...
Sorry for disturbing u, but I’m not so familiar with STL language, so do u have other tested example ....????
I tried to use FB41 in my program , is it ok …???
Hello
Maybe You should start from here
https://www.automation.siemens.com/WW/f ... age=en#top
Here You will find program example for FB41. Also You should call FB41 in some cyclical interrupt OB (for example OB35).
regards
regards
