[?] S7-315PN/DP comunication to S7-400/CP443-1 via ethernet
reymond_craig
Post by reymond_craig »
Good day, I just want to ask if there's a way to communicate CPU351PN/DP to S7-400 CPU with CP443-1 using ethernet network.
And also please provide the block to communicate these two CPU's.
Thank you very much in advance.
Best regards,
Reymond
prodigy_liu
Re: 315PN/DP comunication to S7-400 with CP443-1 using ether
Post by prodigy_liu »
400 need block SFB12 BSEND and SFB13BRCV
300 need block FB12 BSEND and FB13BRCV
dsekulic
Re: [?] S7-315PN/DP comunication to S7-400/CP443-1 via ether
Post by dsekulic »
If You want to use DSEND and BRCV You should configure S7 connection in NetPro.
regards
Umencho
Post by Umencho »
(sfaq) How do you configure a specified and an unspecified S7 connection for data exchange between S7-300 and/or S7-400 by way of Industrial Ethernet CPs?
http://support.automation.siemens.com/W ... n/33118248
reymond_craig
Dear Colleagues,
Happy new year....
My concern is, what should be the block to be use in order to communicate Integrated PROFINET of 315 PN/DP to CP443-1. I'am doing offline programming right now and hopefully do the commissioning by january.
Best regards,
Reymond
dsekulic
Post by dsekulic »
Take a look this manual
https://support.automation.siemens.com/ ... earch.aspx
(sfaq) http://support.automation.siemens.com/W ... n/20982954
Use of proper communication function depends of characteristic of communication partners, amount of data to be exchanged and type of communication (uni- or bi- direction, with or without acknowledgement...)
regards
