hello.
i have an absolute encoder which is 12 bit and 4096 revolutions.
the maximum output value of the encoder is 2^12=4096*4096(revolution)=16777216
i read the encoder value in plc s7-300 in variable table with instruction
pid256 and it showed dw#16#51d72800 this value is greater than the maximum
output value of the encoder(16777216)! why?(if i turn encoder 4096 the maximum output value must be 16777216)!
how can i read encoder value and compare it with 4096 in order to know that
the encoder has been rotated 1,2,3 etc turns?
best regards.
[?]: absolute encoder value is greater than the maximum
seee
NickLu2
Re: encoder value
What kind of input card is used for encoder connection? Maybe it has some memory to count pulses from encoder and thus can be reseted to start counting from zero?i have an absolute encoder which is 12 bit and 4096 revolutions.
Try to make one rotation of encoder and compare values before and after and their differencehow can i read encoder value and compare it with 4096 in order to know that
seee
Re: [?]: absolute encoder value is greater than the maximum
hello.
it is an absolute profibus encoder.i have connected it to dp port of cpu315-2dp.
best regards.
best regards.
NickLu2
Who is the manufacturer of encoder? Can you show the part of program which read and process related input?
Pong Qinaya
i think your Encoder use GRAY CODE
