[?]: Conversion blocks binary-gray (17 bits)
Scarch
Post by Scarch »
Hi all,
I need to convert binary to grey code but siemens requires a password from this page: http://support.automation.siemens.com/W ... n/25629271
Somebody have these blocks available?
Many thanks
Homeroid_BL
Re: Conversion blocks binary-gray
Post by Homeroid_BL »
C'mon, do it youself.
Here is a converter for 4bits, using XOR logic.
Info
Faq & Info
Faq & Info
Re: [?]: Conversion blocks binary-gray
Post by Info »
Scarch
[?]: Convert Gray code to decimal 16 bits
Post by Scarch »
Hi...
I have used a program from Sania in order to convert from gray to decimal for 10 bits, but now I need it for 16 bits (1 word) and do not know how to modify it.
Please help. It is used for an absolute multiturns encoder, being able to read from zero to 65536 in gray code.
I can't manage it.
Nick_N
Re: [?]: Conversion blocks binary-gray (16 bits)
Post by Nick_N »
Wikipedia says there's another formula. STL implementation:
//C formula:
//        unsigned short temp = num ^ (num>>8);
//        temp ^= (temp>>4);
//        temp ^= (temp>>2);
//        temp ^= (temp>>1);
//        return temp;
//Taken from http://en.wikipedia.org/wiki/Gray_code#Converting_to_and_from_Gray_code
// temp = num ^ (num>>8);
      L     #Gray
      SRW   8
      L     #Gray
      XOW
      T     #Temp
      L     #Temp
      SRW   4
      L     #Temp
      XOW
      T     #Temp
      L     #Temp
      SRW   2
      L     #Temp
      XOW
      T     #Temp
      L     #Temp
      SRW   1
      L     #Temp
      XOW
//return temp;
      T     #RET_VAL
Variables #Gray, #Temp and #RET_VAL are of type WORD.
#Gray (IN) = Gray code
#Temp (TEMP) = temporary value
#RET_VAL (RETURN) = result of calculation, binary value
Works for 16-bit Gray code.
