[?+]: Licence problem when install ALL keys
Homeroid_BL
Hi all!
I worked normaly in TIA Stp 7 Professional V11 + SP1 + HF2. Never worked with S7-300, I worked with S7-1200 only.
First time I had to insert a S7-300 station (example S7-314C-2 PN/DP), I got a message that 'No licence key were found'?
You will find screen shots at:
http://s1098.photobucket.com/albums/g378/Homer_BL/
Thanks for a help!
Thanks for a help!
Re: [?]: TIA Portal licence problem
Sorry, but your AX NF ZZ directory is scrapyard.
Do not use short keys for new programs.
Remember for the future - Cheap keys lock expensive keys. See http://support.automation.siemens.com/W ... n/24200966
Use only those keys that you really need.
Do not use the zoom when placing images. See viewtopic.php?f=2&t=5669&p=44957#p44957 How to place screencopy image
Russian wrote:Извините, но ваш каталог AX NF ZZ есть помойка.
Не используй короткие ключи для новых программ.
Запомни на будущее - Дешевый ключ блокирует работу дорогого ключа. Смотри http://support.automation.siemens.com/W ... n/24200966
Устанавливай только те ключи, которые тебе реально нужны.
Не используй масштабирование при размещении картинки. Как разместить картинку в форуме viewtopic.php?f=2&t=5670&p=44959#p44959
Homeroid_BL
Thanks, but I hoped for an answer to my problem.
Removing Basic licence, makes TIA impossible to work even with S7-1200.
Homeroid_BL wrote:Thanks, but I hoped for an answer to my problem.
Restart Windows.
Russian wrote:Удали все ключи.
Установи ключи только для Профессиональной версии.
Перезапусти Windows.
http://support.automation.siemens.com/W ... n/43184652Homeroid_BL wrote:Removing Basic licence, makes TIA impossible to work even with S7-1200.
Удаление Basic лицензии делает невозможным работу TIA даже с S7-1200.
STEP 7 (TIA Portal) Basic V11 S7-1200 TIA Portal License not relocatable, but installed automatically
The licenses for these products are supplied on the installation DVD data medium (that is built into the installer) and are installed automatically during installation by the Setup.
There is no separate installation storage medium (stick, floppy disk) with licenses and you cannot transfer the licenses to other computers.Russian wrote:Лицензии на эти продукты поставляются на установочных DVD носителях данных (то есть встроены в инсталлятор) и устанавливаются автоматически во время установки, настройки.
Не существует отдельного носителя установки (флешки, флоппи-диска) с лицензиями, и вы не можете передавать лицензии на другие компьютеры.
Homeroid_BL
Re: [?]: Licence problem
Homeroid_BL wrote:All short key deleted, PC restarted, useless.
Still not working, still No valid licence key found.
Запомни на будущее - Дешёвый ключ (Basic) блокирует дорогой ключ (Professional). Смотри http://support.automation.siemens.com/W ... n/24200966 Basic v11 = Trial
Устанавливай только те ключи, которые тебе реально нужны.= Удали ВСЕ ключи. Установи только те ключи, которые тебе реально нужны.
Homeroid_BL
Thanks, Comod, but I am too old and too tired to play games here and guess what someone intended to say.
Anyone knows which licence(s) must I have to insert S7-300 in TIA Step 7 V11 Professional?
Thanks.
Thanks.
Homeroid_BL wrote:Thanks, Comod, but I am too old and too tired to play games here and guess what someone intended to say.
TIA Portal Without key - Без ключаHomeroid_BL wrote:Anyone knows which licence(s) must I have to insert S7-300 in TIA Step 7 V11 Professional?
Install 1 key only - Установил только 1 ключ
Result: TIA Portal with 1 key - Результат TIA Portal работает с 1 ключом
Homeroid_BL
Schtiel
Homeroid_BL
Re: [?+]: Licence problem when install ALL keys
In my systems (WXP, W7H, W7H64, W7P32, W7U64) it work correct.Why it say 32 when ONLY ONE key is installed, You must aks a EKB-installer author.
Show Installed software in ALM.
Why in your OS (Vista/Windows 7 ?) it say 32 when ONLY ONE key is installed ?
Why ALM not made request to install Trial key ?
Try in Virtual Machine.
or wait some time SP2.
Homeroid_BL
Homeroid_BL
And why Step7 v5.5 is licensed without key ?
Possible is it ALM bugs.Homeroid_BL wrote:Two reinstall of Step7 V11 SP1 helped
Wait SP2.
Use next construction of Image link - with .th suffix for thumbnail
http://img705.spamm.us/img705/3614/licencee01.jpg full size
http://img705.spamm.us/img705/3614/licencee01.th.jpg thumbnail with .th suffix before .jpg
[url=http://img705.spamm.us/img705/3614/licencee01.jpg][img]http://img705.spamm.us/img705/3614/licencee01.th.jpg[/img][/url]-
Homeroid_BL
CoMod wrote:And why Step7 v5.5 is licensed without key ?
No, Step7 V5.5 is licenced corretcly. You told me to have only one licence, I did it for a short time, but I had to restore V5.5 licence later in order to work with S7-300 in any way.
This snapshot was taken after V5.5 licence is restored.
Still open question, showing '32 licences installed' whe only one licence were intalled.
But, It works for me, no complain there
Thanks!
