[?]: unpassword Twido
другие контроллеры
Guest
Post by Guest »
I have a program Twido *. twd i open it with hex editor , and I remove the password,to remove the entire line password.
but the problem , I want to know how to decrypt the numbers between the two words password.
line 180 to 1A0 <Password>132135121116111115111102</Password>
132135121116111115111102   =   0000
141143128122111115111102   =   9876
111102111115129125138142   =   6789
please i need the answer
c0den
Re: [?]: unpassword Twido
Post by c0den »
Is this in decimal? Do you have any hex number listing of these crypt passwords?
Like: 0x4F, 0x33, 0x20....
Also, try to put some easy passwords, to see if this algo is linear or non-linear, using passwords like:
0001, 0002, 0003, 0010, 0100, ....
It´s easier to find some algorithms using hex instead of decimal...
c0den
vlad2006gr
Post by vlad2006gr »
Why is it know? I do not know exactly. Send the project to try to calculate the password.
Вроде алгоритм понятен, только зачем это? Достаточно удалить всю строку: <Password>XXXXXXXXXXXXXXXXXXXXXX</Password> открыв в любом текстовом редакторе файл проекта с расширением *.xtwd и сохранить. Проект останется без пароля.
Good luck!
Guest
Post by Guest »
thanks for yours answer
find attache file in 4sharde
http://www.4shared.com/file/4mJYJrSj/vals_v2_21.html
1 the original password is = alameh13
2 how can decrypt the password inside
3 if i have another twido how can unpassword
vlad2006gr
In Twido password allowed the digits 0 - 9 and letters A-Z of length 8.
Password 00000000 As the project is: 132135121116127131127118.
Further Mathematics.
149163138145148155128121 - 132135121116127131127118 = 17028017029021024001003
Translation:
Spoiler
Show
17 A
180 B
190 C
200 D
210 E
220 F
230 G
240 H
250 I
260 J
270 K
280 L
290 M
300 N
310 O
320 P
330 Q
340 R
350 S
360 T
370 U
380 V
390 W
400 X
410 Y
420 Z
010 1
020 2
030 3
040 4
050 5
060 6
070 7
080 8
090 9
000 0
The numbers in groups of three divide.
If the front after the first digit immediately to zero then you need to add a zero.
Highlighted in the second example in large print.
Sample:
Password: Alameh13
<Password>149163138145148155128121</Password>
A___ l ___a__m__e__h___1___3
170 280 170 290 210 240 010 030
Password: 1qwerty5
<Password>133168160137161167168123</Password>
1___q___w___e__r___t___y__5
010 330 390 210 340 360 410 05
Пароль 00000000 в файле проекта будет выглядеть как 132135121116127131127118.
Отнимаете это значение от того , что есть в проекте и получаете значение пароля. Расшифровку значений смотрите выше. Результат нужно разбить по три цифры, с учетом того, что если после первой цифры идет ноль, то спереди добавляем ноль.
Возможно, что не для всех проектов Пароль 00000000 = 132135121116127131127118, тогда нужно в проекте ввести пароль из восьми нулей и посмотреть результат.
U_gene
Post by U_gene »
Влад, у меня к сожалению не получается. Пароль в Twido 139142128123134138134070. Восемь нулей у меня 132135121116127131127118. Вычитая, получаем 070 070 070 070 070 070 069 52. Как его преобразовать в реальное значение? Заранее благодарен.
vlad2006gr
U_gene wrote:Влад, у меня к сожалению не получается.
Ваш пароль 7777777
И если не получается, лучше выкладывать проект и спрашивать. Если число пароля меньше 8 цифр, алгоритм расчета изменяется немного.
U_gene
Post by U_gene »
Влад, спасибо большое! Помогло.
Правда, так и не понял, как алгоритм расчета работает. Влад, объясните, пожалуйста на моём примере. Чтобы Вас больше подобные мне не напрягали.
vlad2006gr
In the example given way to determine the password to 8 characters. If any of the numbers are not defined, then the password characters less.
U_gene wrote:Password in Twido 139142128123134138134070. Eight zeros = 132135121116127131127118. Subtracting, we get 070 070 070 070 070 070 069 52
Combinations 069 520 (do not forget to complement zeros, each character of the three digits) -no match. So in the password is less than 8. Create an empty project and put it out the password zeros characters 7,6,5, etc. In each case, you get a new combination of digits. It is this combination and defraud. If you take a combination of the password of 7 zeros, you will receive 070 070 070 070 070 070 070 000. The last zeros are dropped. You can check, even though I was doing a different method.
Rus:
В примере дан способ определения пароля для 8 знаков. Если какие то цифры не определяются, значит в пароле знаков меньше.
U_gene wrote:Пароль в Twido 139142128123134138134070. Восемь нулей у меня 132135121116127131127118. Вычитая, получаем 070 070 070 070 070 070 069 52
Комбинации 069 520 (не забываем дополнять нулями, каждый символ из трех цифр) -нет соответствия. Значит в пароль меньше 8. Создаете пустой проект и ставите на него пароль из нулей знаков 7,6,5 и т.д. В каждом случае получаете новую комбинацию цифр пароля. Вот эту комбинацию и отнимаете. Если отнять комбинацию пароля из 7 нулей, то получите 070 070 070 070 070 070 070 000. Последние нули отбрасываются. Можете проверить, хотя я делал по другому методу.
Если кто сможет, переведите на английский, у гуглы как-то плохо получилось.
full power
Post by full power »
whit password string <Password>132135121116111115111102</Password>
change it like this <Password>$</Password>
and save as
now is free password
Если у вас есть пароль , как это <Password>132135121116111115111102</Password>
После написания знака в плотном $ <Password>$</Password>
Изменение и сохранение
удачи вам
marmagi
Post by marmagi »
First of all , excuse me if I am so ignorant I dont know how , but please help us
we need to recover or unprotect password in a TWIDO but without loosing the software inside
can anyone help us? we are willing to also pay for the help
thanks so much
mario
washtecnic@hotmail.com
