I have this little problem with license.
Simatic EKB 2011_05_22 doesn't have key for this one, so where can i find this?
I'm using TIA 2011 (Step7 Professional, WinCC Basic v11) and I'm obligated to using this software.
I would really appreciate your help.
[?+]: TIA 2011 WinCC Basic v11 key installed automatically*
iluv
Re: [?]: TIA 2011 WinCC Basic v11
but it not required
http://support.automation.siemens.com/W ... n/43184652
STEP 7 (TIA Portal) Basic V11 S7-1200 TIA Portal License not relocatable, but installed automatically*
*The licenses for these products are supplied on the installation data medium and are installed automatically during installation by the Setup.
There is no separate installation storage medium (stick, floppy disk) with licenses and you cannot transfer the licenses to other computers.
How for TIA Portal Basic v10.5
iluv
Re: [?+]: TIA 2011 WinCC Basic v11 key installed automatical
Then it had to be some software malfunction, because i installed keys from EKB 2011 and didn't delete anything. For a while it was fine. After a few weeks however, I couldn't open any screen or create new screen for HMI, and it stated in info box that there is license key missing.
I reinstalled TIA, and during installation used EKB to license it. All is working fine now.
In next time Run ALM and press the PrintScreen keyboard button.iluv wrote: After a few weeks however, I couldn't open any screen or create new screen for HMI, and it stated in info box that there is license key missing.
Place the screencopy
How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
http://support.automation.siemens.com/W ... n/24200966
