[?]: Wincc runtime license error by PCS7 7.0
RZH_reza
Post by RZH_reza »
Hi
i have instaled pcs7 7.0 and one project with 14000 tag and 275 po i have installed license
but wincc announce you have not license please help
2011-10-29 12:11:59
License   			installed			needed			to install			Product
SIFLYMAINR0700			Yes  [TTF-ZARDOSHT]		Yes      			No        			Maintenance RT (Count Relevant)
SIFCY9WTGX06022			Yes  [TTF-ZARDOSHT]		Yes      			No        			WinCC Option Archive (Count Relevant)
SIFLA9WRP30602			Yes  [TTF-ZARDOSHT]		Yes      			No        			WinCC Runtime PO 2000 ProcessObjects 512 Archive Tags
SIFLA9WC170602			Yes  [TTF-ZARDOSHT]		No      			No        			Channel SIMATIC S5 Ethernet TF
SIFLA1SFCV0700			Yes  [TTF-ZARDOSHT]		No      			No        			SFC-Visualization
SIFLA9WC180602			Yes  [TTF-ZARDOSHT]		No      			No        			Channel SIMATIC S5 Ethernet Layer 4
SIFLA9WC190602			Yes  [TTF-ZARDOSHT]		No      			No        			Channel SIMATIC TI Ethernet Layer 4
SIFLA9WVC10602			Yes  [TTF-ZARDOSHT]		No      			No        			Dat@Monitor 3 Clients
SIFLA9WCL60602			Yes  [TTF-ZARDOSHT]		No      			No        			Channel PROFIBUS FMS
SIFLA9WARC0602			Yes  [TTF-ZARDOSHT]		No      			No        			User Archives
SIFLMAINES0700			Yes  [TTF-ZARDOSHT]		No      			No        			Maintenance ES
SIFLA1WPC20602			Yes  [TTF-ZARDOSHT]		No      			No        			Advanced Process Ctrl
SIFLA9WC250602			Yes  [TTF-ZARDOSHT]		No      			No        			Channel SIMATIC 505 TCPIP
10/29/2011 12:01:38 InitLicense RT | AppName = OptRT:CHIPCARD | CycleCheck = no | NameForMessageBox = | Name of License = A1WPC40602 | Text of License = |
10/29/2011 12:01:43 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRP30602 | Text of License = WinCC RT PO (2000) | Relevant Limit = 0000002000 |
10/29/2011 12:01:43 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCY9WTGX06022 | Text of License = WINCC Arch (5000) | Relevant Limit = 0000005000 |
10/29/2011 12:02:07 Control Center - Demo Mode Runtime enabled -
10/29/2011 12:02:07 NoLicense RT | Name of License = YMAINR0700 | Text of License = | Exists = No |
10/29/2011 12:02:07 InitLicense RT | AppName = OptRT:OSStateMachinex | CycleCheck = yes | NameForMessageBox = | Name of License = YMAINR0700 | Text of License = |
29.10.2011 12:01:37 License_Info start -----------------------------------------------------------------------
29.10.2011 12:01:37 Is PCS7 project -> PO Licensing
29.10.2011 12:01:37 PO Licensing Mode -> POs:275 Tags:14629
29.10.2011 12:01:38 PO Licensing Mode -> POs:275 Tags:14629
29.10.2011 12:02:07 No runtime licence: Type:OptRT:OSStateMachinex Key: -> Activating demo mode
Re: [?]: Wincc runtime license error by PCS7 7.0
For open project you need Enginering Station licenses - ES PO and Asset ES
How about DuQu in Iran ?
http://www.symantec.com/connect/blogs/w ... xt-stuxnet
RZH_reza
Post by RZH_reza »
hi
thank for your inform but after install your advise , i have the flowing alarm's
is these because we used "DIAGNOSTIC"
10/30/2011 17:05:36 InitLicense RT | AppName = OptRT:CHIPCARD | CycleCheck = no | NameForMessageBox = | Name of License = A1WPC40602 | Text of License = |
10/30/2011 17:05:45 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRP90602 | Text of License = WinCC RT PO (unlimited) | Relevant Limit = 2147483647 |
10/30/2011 17:05:45 InitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WSEC0602 | Text of License = WinCC Server |
10/30/2011 17:05:45 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRP90602 | Text of License = WinCC RT PO (unlimited) | Relevant Limit = 0000000512 |
10/30/2011 17:06:08 InitLicense RT | AppName = OptRT:REDCODI | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WSRD0602 | Text of License = WinCC Redundancy |
10/30/2011 17:06:36 Control Center - Demo Mode Runtime enabled -
10/30/2011 17:06:36 NoLicense RT | Name of License = YMAINR0700 | Text of License = | Exists = No |
10/30/2011 17:06:36 InitLicense RT | AppName = OptRT:OSStateMachinex | CycleCheck = yes | NameForMessageBox = | Name of License = YMAINR0700 | Text of License = |
30.10.2011 17:05:35 License_Info start -----------------------------------------------------------------------
30.10.2011 17:05:35 Is PCS7 project -> PO Licensing
30.10.2011 17:05:36 PO Licensing Mode -> POs:436 Tags:11360
30.10.2011 17:06:36 No runtime licence: Type:OptRT:OSStateMachinex Key: -> Activating demo mode
also i heard something about DuQu but i didn't see it yet
thank
install SIFLA9WCP90602 and SIFLMAINES0700
after this check keys an ALM
try to remove Runtime licenses SIFLYMAINR0700 and SIFLA9WRP30602
