[?]: Write variable of type DT to DB
waard
Post by waard »
I try to do this with command MOVE, but data type DT does not work with that command. 8 bytes.....
How i can do that?
thanks.....
Info
Faq & Info
Faq & Info
Re: [?]: Write variable of type DT to DB
Post by Info »
you need to use SFC20 "BLKMOV"...
waard
Post by waard »
OK, thanks..
Maybe i dont understand how it working, but what i do:
i am using SFC1( read clk) and save value to TEMP0, then i am using SFC20 - TEMP0 as SRCBLK and DB1.DBW2 (that adress of variable in DB having type DT) as DSTBLK , but that not working.
To tranfer another variable, having type INT - all OK.
In cpu how i can to set the real time in HW (in step 7)? (not in program using SFC)
May be the time in CPU didn't go....
peterc101
Post by peterc101 »
just put a pointer to your first bit of you db where you made 8 bytes for DT as output of sfc1
