?:How to update ELAU motor controller MC-4 firmware <= V15.x
другие контроллеры
iop_p
Post by iop_p »
Hi all,
I have a very urgent problem with ELAU MC-4 firmware update, I tried a lot of methods to solved it used my DIY sreial cable, but alaways failured
front view
pinout
Now I write the step what I had done:
A.
MC-4 side------------------------------------------PC side
2-----------------------------------------------------3
3-----------------------------------------------------2
4-----------------------------------------------------5
Result:
Firmware Assistant can't detcted the moudle
B.
MC-4 side--------------------------------------------PC side
2-----------------------------------------------------2
3-----------------------------------------------------3
Result: The same as above
C.
MC-4 side-------------------------------------------PC side
5-----------------------------------------------------5
Result:
Firmware Assistant can detcted the moudle now
but it alaways let me try lower baudrate
D.
4-----
Result: The same as above.
E.
6------
So, what should I do now, does anybody have an idea, pls share to me. Thanx (sos) (fback)
SSSeif
Re: ?:How to update ELAU motor controller MC-4 firmware <= V
Post by SSSeif »
hello!
did you find a solution? i have the same problem...
apilife
Post by apilife »
Some ELAU guys seem to have symmetry difficulty with pinouts...
Here is my cable pinout diagram.
Be careful: always shut down power before connecting or disconnecting cable on X7... or this port may definitely burn out !
It is much a better way to upgrade MC4 firmware through the controller with Ethernet connection when possible !
serg77
Post by serg77 »
Hey.
apilife
Thank you very much for the description of the cable to the MC-4.
And where can I download the latest firmware for the MC-4?
apilife
Post by apilife »
You can look for firmware on http://www.elau.com/downloads.html
First you have to register, then look in PacDrive M downloads.
serg77
Post by serg77 »
Hi
I was there but there is no firmware. Once the program
PacDrive Diagnostics.
apilife
Post by apilife »
After login, I see the firmware files (Downloads -> Download PacDrive M -> Software -> Firmware).
Here is the direct link : http://www.elau.com/fileadmin/user_uplo ... 05_MC4.zip
serg77
Post by serg77 »
apilife (tyou)
Thank you very much!
jackberg
Post by jackberg »
Hi there,
Have you solved your problem? Because I have the same communication problem. Tried the pinout mentionned. Also, I can't find the Pacdrive Sercos firmware assistant software anywhere on the Elau website. Does anyone have it?
serg77
Post by serg77 »
Hello everyone.
To jackberg
The problem was solved. I have an assistant for the firmware.
This service CD. There's a lot of interesting things.
http://yadi.sk/d/JoDyE5gsGAX89
The password-a personal message.
Rudi_budi
Post by Rudi_budi »
Hi all,
I have got download from this link,
don't understand about password...please help?
anyone please
serg77
Post by serg77 »
Hello everyone.
Password for archive ----- sercos1977
Use luck :D :D :D
Rudi_budi
Post by Rudi_budi »
Hello serg777,
Thanks a lot (clap) 8) (clap)
Rudi_budi
usefi5961
Post by usefi5961 »
dear all:
i want connect to packdrie diagnostics software but by building cable (aboe schematic)i can not connect to drive please if anyone help me send fresh schematic for building this cable.
4----------------2
1----------------3
2,3----------------5
japiejoo
Post by japiejoo »
hello everyone
I need Firmware version V00_12_52 for my MC-4
kan anybody help me, i can't found this file
Thanks ans regards
Hans
guerik
Post by guerik »
great Thanks.
goffka
Post by goffka »
Thank you so much for all the listed information.
Successfully update firmware on the MC4.
For some reason, there was an error on the drive and is not reset. All elements are intact. Firmware was 22.05, I again flashed the same drive and earned.
All thanks again!
esvblog
Post by esvblog »
Hi and helloo.
First i've read all info from this post.
And i do have trouble with connection.
I've made cable as is shown (i have doubt that i do not make mistake) there is no ifo from where i see connector to MLAU.
But i have found GND
But still no connection
i see on scope that computer sending some transmit. But no receive at all.
i have two MC-4 and on both the same situation.
i have use a diagnostics v3 tool (from schneider)
What i do wrong ?
do i have to connect pin 6 or 5 ?
or maybe pin PRO_sel i have to disconnect or connect to +5V
Best regards
Mark
esvblog
Post by esvblog »
It is solved...
i have conflict with RS drivers from other programs.
i have made succesfully update firmware :D
Thanks a lot.
aleksei112
Post by aleksei112 »
The problem with connecting to Elau mc 4 is up-to-date, did everything as it is written above - it was not possible to connect.
I will be grateful for help
ramiers
Post by ramiers »
Hi, could you tell me how to upgrade through the controller? tx
usefi5961
Re: ?:How to update ELAU motor controller MC-4 firmware <= V15.x
Post by usefi5961 »
dear members:
sorry,i try to connect to mc4 by firmware assistant and pacdrive diagnostics by rs232 cable but i can not connect to drive,please help me how can i connect to it and what is rs232-sel and pro-sel pin of x7 connector?(my pacdrive mc4 is version 16.32)
Hassanazhar92
Post by Hassanazhar92 »
Bro I have done everything you said.
but still getting the Error "Couldn't set the required baudrate. Try it with a lower baud rate"
Can you please share how did you solve it.
Its urgent
goffka
Post by goffka »
Updated it a week ago again. There was no connection either. I managed to connect under the following conditions:
1 program is open and waiting for connection.
2 rs232 cable is connected.
3 ONLY after that connect 24v power.
Connection Speed ​​115.
Try it. If it doesn’t work out - write to me
celiodalmagro
Post by celiodalmagro »
Hi. New on this forum. Thanks in advance for any help.
Does anyone have or know how to get Firmware_MC-4_V00_12_02?
Thanks.
pwnst4r
Post by pwnst4r »
Wow, thank you apilife!
Every "official" document regarding the pinout of the 6-pin mini DIN diagnostic cable was written by morons.
You are absolutely correct that they have an issue with symmetry. More like Elau/Schneider can't tell the difference between their ass and their head (though it doesn't matter, because they are all ass heads, hahahahah).
Thank you, as well, goffka. I followed your steps and had success in downgrading this junk MC-4 servo to an older firmware.
You rock, dudes!
TNC1971
Post by TNC1971 »
Hello guys..can anyone give me in detail of a correct wiring of serial cable from MC-4 to PC (serial port db9 male) please?
Thank you so much in advance
TNC1971
Post by TNC1971 »
Unfortunately I can’t see a cable pin out diagram from Apilife on above chat..
(fback)
Danish
Post by Danish »
celiodalmagro wrote: Thu May 07, 2020 7:25 pm Hi. New on this forum. Thanks in advance for any help.
Thanks.
apilife wrote: Thu Dec 19, 2013 3:42 pm After login, I see the firmware files (Downloads -> Download PacDrive M -> Software -> Firmware).
apilife
Post by apilife »
thanhlong_VN71
Post by thanhlong_VN71 »
Could you please share the download link for the software with me?
(fback)
