[?]: EPLAN Electric P8 v2.1.4 "DONGLES Emulator" problem
Тools, Elcad, Eplan, ...
xflash
Post by xflash »
Greetings~
I am using win7 32bit, And installed EPLAN Electric P8 v2.1.4. I activated it by DONGLES Emulator.
After I done all this, I try to uninstall emualtor by saying this.
SO what is the meaning of this? I have only one chance to activate EPLAN. If I uninstall that emualtor and I could not install again? Any solutions? :) :) :)
Or I just misunderstood? :haha: :haha: :haha:
Information
You will not be able to install emualtor on this computer again without Update Code
Are you sure?
OK Cancel
P.S. I uploaded the dongles to http://www.mediafire.com/?w1cs913hgkjmghd
Thank you all~
sadefa
Re: [?]: EPLAN Electric P8 v2.1.4 "DONGLES Emulator" problem
Post by sadefa »
why don't you just use this:
here is a link for the video. Sorry for the poor quality of the speech, but the mic I used was quite old.
Download link for video:
http://www.filesonic.com/file/2304448901/Eplan2.1.mp4
Download link for patch:
http://www.filesonic.com/file/2216098681
Instructions:
1. Download the rar archive from http://www.filesonic.com/file/2216098681
2. Set UAC to minimal. (User account control)
3. Install EPLAN 2.1
4. Copy the file that is into the common folder from the rar and paste it to C:\Users\Public\EPLAN\COMMON.
5. Go to control panel. There you will find licence client. Right click and click change. There you can disable the HL drivers.
6. Install the new drivers (provided into the rar - HASPUserSetup.exe)
7. Add the data to the registry by running 5189.reg from the archive
8. Go to the Release folder and then to x32 or x64 (depending from your PC and OS) and run install.cmd
9. Run dseo13b.exe and enable test mode.
10. Restart your computer
11. Run dseo13b.exe and sign a file. The address of the file is C:\Windows\System32\Drivers\multikey.sys
12. Restart your computer
13. EPLAN 2.1 is running
PS. All the tutorials are really similar, but the problem comes form the files that are included into the download archives. For example I saw a link for 2.1 crack and the license file was for 2.0 ... or the registry file is for other license file. With this one everything is OK, I personally got 2.1 running with this. If you still have problem, uninstall all drivers, uninstall Mkey and license client. Install Eplan LC and you are back to step 3 and try again.
I hope I helped.
viewtopic.php?f=7&t=16459
xflash
Post by xflash »
Thank you for reply, It was quite a long way to do that.
Using DONGLES Emulator is much easier in 32 bit environment, it never modifies any existed file. It provided same service as it should be. :) :) :)
I will check it again~
grmm
Post by grmm »
Instructions:
1. Disable AV
2. Download the rar archive from http://www.filesonic.com/file/2216098681
3. Set UAC to minimal. (User account control)
4. Install EPLAN 2.1
5. Copy the file that is into the common folder from the rar and paste it to C:\Users\Public\EPLAN\COMMON.
6. Go to control panel. There you will find licence client. Right click and click change. There you can disable the HL drivers.
7. Install the new drivers (provided into the rar - HASPUserSetup.exe)
8. Add the data to the registry by running 5189.reg from the archive
9. Go to the Release folder and then to x32 or x64 (depending from your PC and OS) and run install.cmd
10. Run dseo13b.exe and enable test mode.
11. Restart your computer
12. Disable AV, copy multikey.sys to c:\privremena_mapa\multikey.sys and Run dseo13b.exe and sign a file. The address of the file is c:\privremena_mapa\multikey.sys!!!!!!
13 copy c:\privremena_mapa\multikey.sys to C:\Windows\System32\Drivers\multikey.sys
14. Restart your computer
15. NEW HARD...UPDATING.....
16. EPLAN 2.1 is running
xflash
Post by xflash »
Thank you a lot. It was a different way, this method is crack the HardLock. My way is simulate the genius dongles.
It seems few people use the dongles simulator. Hope to help someone, because the dongles simulator is always working, even in the future version.
Thank you all :) :) :)
