Hi all,
In PCS7 project I need to move indexed db data from one to other, but with different lenght....
For example I will need to define a start address like db10.dbx2.5 and a bit lenght like 30 (...so it will last 'till db10.dbx6.2) to a destination address like db20.dbw4 with the same lenght.
What I would like to have on my scl code is as Input parameters the "dbnn.dbxn.n" and "bit lenght" and the destination "dbnn.dbwnn" as output.
Anyone can give me a clue how to make it... or maybe someone have a code that makes it ??
Best regards,
[?]: Move DB data from one to other in SCL
dehell
Re: [?]: Move DB data from one to other in SCL
Search for SFC20 BLKMOV in Siemens Step7 help.
An other solution : use google and search for oscat.de : you could find a SCL block library for free.
Best regards.
Best regards.
cabrca
Thanks for the answer...dehell wrote:Hi,
Best regards.
I will try and inform.
Best regards
Janosch07
Spoiler
FUNCTION_Block "CopyDB"
AUTHOR : Someone
FAMILY : MoveDB
VERSION : '1.0'
KNOW_HOW_PROTECT
VAR_INPUT
Source : INT; // Source DB
Destination : INT; //Distination DB
END_VAR
VAR_OUTPUT
Error : WORD;
END_VAR
VAR_IN_OUT
Execute : BOOL ; //Execute Copy
END_VAR
VAR_TEMP
tiX : INT;
RETVAL : INT;
tiSourceDBLength : WORD;
tiDestinationDB1Length : WORD;
tbWriteProtected : BOOL;
END_VAR
BEGIN
IF Execute THEN
Error := 0;
// Get information of source DB
RETVAL := TEST_DB(DB_NUMBER := INT_TO_WORD(Source), DB_LENGTH := tiSourceDBLength, WRITE_PROT:=tbWriteProtected);
// If TEST_DB for source DB function was executed error free, the continue, otherwise indicate the error
IF RETVAL = 0 THEN
RETVAL := TEST_DB(DB_NUMBER := INT_TO_WORD(Destination), DB_LENGTH := tiDestinationDB1Length, WRITE_PROT:=tbWriteProtected);
// If TEST_DB for destination DB function was executed error free, the continue, otherwise indicate the error
IF RETVAL = 0 THEN
// Check if destination DB write protected
IF tbWriteProtected THEN
Error := W#16#000A; // Write protection error W#16#A
ELSE
IF tiSourceDBLength = tiDestinationDB1Length THEN // Check if both DBs have the same length
// both DBs have the same length. copy source to destination
FOR tiX := 0 TO (WORD_TO_INT(tiSourceDBLength) - 2) BY 2 DO
// word by word copy
WORD_TO_BLOCK_DB(INT_TO_WORD(Destination)).DW[tiX] := WORD_TO_BLOCK_DB(INT_TO_WORD(Source)).DW[tiX];
END_FOR;
ELSE // If length differs then output error W#16#B (Length Error)
Error := W#16#000B;
END_IF;
END_IF;
ELSE // destination DB error
Error := INT_TO_WORD(RETVAL);
END_IF;
ELSE // Source DB error.
END_IF;
Execute := False;
END_IF;
cabrca
Hi Janosch07,Janosch07 wrote:This code is proven working :
Enjoy
Tested and working. Your code copies a complete DB to another one exacty equal, but it does not makes exactly what I need.
I need to copy parts from one DB to another , but de source data may not start in DWn.0 and with a lenght different than 16 or 32 bits.
The source data I need to move is for example 30 bits starting in address db20.dbx2.4 and move them to another DB starting for example in the address db21.dbx0.0 .
How can I point to bits instead of words using an instruction like the one you've used:
WORD_TO_BLOCK_DB(INT_TO_WORD(Destination)).DW[tiX] := WORD_TO_BLOCK_DB(INT_TO_WORD(Source)).DW[tiX]; -
dehell
I test on PLCSIM and it seem OK
Best regard
Spoiler
FUNCTION_BLOCK FB505
TITLE = 'Bit_DB_AREA_to_Word_DB_AREA'
//Take care, this block don't check if DB exist or enough long...
// Instruction
VERSION : '1.0'
AUTHOR : Dehell
FAMILY : BTW
VAR_INPUT
DB_IN: INT;// INPUT DB number
IN_BYTE:INT;// INPUT Byte number
IN_BIT:INT;// INPUT bit number
DB_OUT:INT;// OUTPUT DB number
DEST_WORD:INT;// OUTPUT Word number
LENGH:INT;// Number of bit to copy
END_VAR
VAR_OUTPUT
DONE:BOOL;
END_VAR
VAR
NUM_DB_IN: WORD;
NUM_DB_OUT:WORD;
NUMBER_BYTE:INT;
NUMBER_BYTE2:INT;
INDEX1:INT;
INDEX2:int;
INDEX3:INT;
INDEX4:INT;
INDEX5:INT;
MASK:BYTE;
NBR_BIT_MASK:INT;
BYTEARRAY: ARRAY[0..31]OF BYTE;// maximum 256 bits : you can increase this value
BITARRAY2:ARRAY[0..255]OF BOOL;
BYTEARRAY2 AT BITARRAY2:ARRAY[0..31]OF BYTE;
BITARRAY1 AT BYTEARRAY :ARRAY[0..255]OF BOOL;
END_VAR
BEGIN
NUM_DB_IN:=INT_TO_WORD(DB_IN);
NUM_DB_OUT:=INT_TO_WORD(DB_OUT);
DONE:=FALSE;
IF LENGH < 8 THEN
RETURN;// if LENGH<8 this function is aborted
ELSE
// Number of byte calculation
NUMBER_BYTE:=(LENGH/8)+1;
NUMBER_BYTE2:=(LENGH/8);
END_IF;
// Copy DB_IN into BYTE ARRAY
FOR INDEX1:=0 TO NUMBER_BYTE DO
BYTEARRAY[INDEX1]:=WORD_TO_BLOCK_DB(NUM_DB_IN).DB[IN_BYTE+INDEX1];
END_FOR;
// Copy ARRAYBIT1 into ARRAYBIT2 with offset
FOR INDEX2:=0 TO LENGH DO
BITARRAY2[INDEX2]:=BITARRAY1[INDEX2+IN_BIT];
END_FOR;
//Copy ARRAYBIT2 into WORDARRAY
FOR INDEX3:=0 TO (NUMBER_BYTE2-1) DO
WORD_TO_BLOCK_DB(NUM_DB_OUT).DB[DEST_WORD+INDEX3]:= BYTEARRAY2[INDEX3];
END_FOR;
// For last BYTE, create Mask
NBR_BIT_MASK:=((LENGH-(NUMBER_BYTE2*8))-1);
INDEX5:=DEST_WORD+(NUMBER_BYTE2);
FOR INDEX4:= 0 TO 7 BY 1 DO
IF INDEX4 >=0 AND INDEX4 <= NBR_BIT_MASK THEN
WORD_TO_BLOCK_DB(NUM_DB_OUT).DX[INDEX5,INDEX4]:= BITARRAY2[((NUMBER_BYTE2*8)+1)+INDEX4];
END_IF;
END_FOR;
DONE:=TRUE;
END_FUNCTION_BLOCKBest regard
cabrca
Excellent answer dehell... This is exactly what I needed !!!!!
Thanks a lot !!
Thanks a lot !!
Janosch07
Hi Cabrca,
Try this code for copying bits
test and see if it's good for you
Regards
Spoiler
FUNCTION_Block "CopyDBBits"
AUTHOR : abcd
FAMILY : efgh
VERSION : '1.0'
KNOW_HOW_PROTECT
VAR_INPUT
SourceBitOffset : INT; // Offset to start bit of source DB. (if DBx.DBX8.7 then Offset = 7)
DestinationBitOffset : INT; // Offset to start bit of destination DB. (if DBx.DBX1.0 then Offset = 0)
SourceByteOffset : INT; // Offset to start byte of source DB. (if DBx.DBXB8.7 then Offset = 8)
DestinationByteOffset : INT; // Offset to start byte of destination DB. (if DBx.DBX1.0 then Offset = 1)
// Offset must be between 0 and 7
BitsToMove : INT; // Number of bits to copy
END_VAR
VAR_OUTPUT
Error : WORD;
END_VAR
VAR_IN_OUT
END_VAR
VAR_TEMP
tiX : INT;
RETVAL : INT;
tiSourceBit : INT;
tiDestinationBit : INT;
tiSourceByte : INT;
tiDestinationByte : INT;
twSourceDBLength : WORD;
twDestinationDBLength : WORD;
END_VAR
BEGIN
IF Execute THEN
Error := 0;
RETVAL := TEST_DB(DB_NUMBER := INT_TO_WORD(Source), DB_LENGTH := twSourceDBLength, WRITE_PROT:=tbWriteProtected);
IF RETVAL = 0 THEN
RETVAL := TEST_DB(DB_NUMBER := INT_TO_WORD(Destination), DB_LENGTH := twDestinationDBLength, WRITE_PROT:=tbWriteProtected);
IF RETVAL = 0 THEN
ELSE
// No errors when evaluating DBs information. copy source to destination
// Check for Parameter errors
IF ((INT_TO_WORD(SourceBitOffset) OR 16#7) <> 7) THEN
Error := W#16#000C; // Source bit offset out of range
END_IF;
IF ((INT_TO_WORD(DestinationBitOffset) OR 16#7) <> 7) THEN
Error := W#16#000D; // Source bit offset out of range
END_IF;
tiSourceBit := SourceBitOffset; // Initialise the source bit pointer
tiDestinationBit := DestinationBitOffset; // Initialise the destination bit counter
tiSourceByte := SourceByteOffset; // Initialise the source byte counter
tiDestinationByte := DestinationByteOffset; // Initialise the destination byte counter
// First, check for length errors
// Note : the length of a DB is always an even number. If for example the last entry in a DB is DBX6.7, this function will allow writing up to
// DBX7.7 and beyond that an error is returned
FOR tiX := 0 TO (BitsToMove - 1) DO // loop through the number of required bits to copy
IF ((tiDestinationByte + 1) > WORD_TO_INT(twDestinationDBLength)) THEN // Check if destination byte pointer exceeds the length of the destination DB
Error := W#16#000E; // Copy of bits interrupted due to possible write error on destination DB
END_IF;
IF ((tiSourceByte + 1) > WORD_TO_INT(twSourceDBLength)) THEN // Check if destination byte pointer exceeds the length of the source DB
Error := W#16#000F; // Copy of bits interrupted due to possible read error from source DB
END_IF;
IF Error <> 0 THEN
EXIT;
END_IF;
WORD_TO_BLOCK_DB(INT_TO_WORD(Destination)).DX[tiDestinationByte,tiDestinationBit] := WORD_TO_BLOCK_DB(INT_TO_WORD(Source)).DX[tiSourceByte,tiSourceBit];
tiDestinationBit := tiDestinationBit + 1; // increment source bit pointer by 1
tiSourceBit := tiSourceBit + 1; // increment destination bit pointer by 1
IF tiDestinationBit > 7 THEN // If bit higher than 7 then
tiDestinationByte := tiDestinationByte + 1; // increment byte pointer by 1
tiDestinationBit := 0; // reset bit pointer to 0
END_IF;
IF tiSourceBit > 7 THEN // If bit higher than 7 then
tiSourceByte := tiSourceByte + 1; // increment byte pointer by 1
tiSourceBit := 0; // reset bit pointer to 0
END_IF;
END_FOR;
END_IF;
END_IF;
END_IF;
Execute := False;
END_IF;
END_FUNCTION_BLOCK
Regards
