Hi!
I have a problem: I need activate couple outputs (for example, 1 and 3) on Outputs module 6ES5454-7LA11 when processor 6ES5942-7UB11 is started. I use STEP5 software to communicate with processor.
Please, give me some examples.
Thanks!
[?]: I need example to activate Output Module S5
andreyneyko
dekor
Re: [?]: I need example to activate Output Module S5
try next example.
try next example.
Block: OB 001
Segment 1 of 1 zyclic block Lib =
:JU PB 3
:BE
Block: OB 021 File:
Segment 1 of 1 Stop -> Run Lib =
:S Q 0.1
:S Q 0.3
:BE
Block: OB 022
Segment 1 of 1 absence of power ! Lib =
:S Q 0.1
:S Q 0.3
:BE
Block: PB 003
Segment 1 of 4 Lib =
:A Q 0.1
:L KT 0003.2
:SD T 1
:NOP 0
:NOP 0
:NOP 0
:NOP 0
Segment 2 of 4
:A Q 0.3
:L KT 0003.2
:SD T 2
:NOP 0
:NOP 0
:NOP 0
:NOP 0
Segment 3 of 4
:A T 1
:R Q 0.1
Segment 4 of 4
:A T 2
:R Q 0.3
:BE
