Hi friends,
I'm new here, nice to meet you!
I created a project using Starter but after I needed to install Simotion Scout and it prompt me to delete Starter so I did it.
but now while I want to open the project with simotion i get an error,
it said that the project was created with a later version that is not compatible with simotion...
How to do?, If I delete the drive from the project I get another error for the same reason..
[?]: Starter project cannot be opened by Simotion Scout?
avafab
peterfrick
Re: [?]: Starter project cannot be opened by Simotion Scout?
You can not install Simotion and Starter at the same time.
Both are different.
You can only install Starter or Simotion.
Why you want to open project in Simotion?
Both are different.
