AB RSLinx Software
Christine_1914
AB RSLinx Software
Post by Christine_1914 »
Hi, (sos)
I am currently working on an AB project.
I just want to know:
1.If there is any difference between RSLinx Classic Gateway CPR 9 SR1 and RSLinx Classic Gateway CPR 9 SR3.
2. Does it matters if I loaded RSLinx Classic Gateway CPR 9 SR3 to run RSView32 CPR 9 SR1?
3. Is there something that I still need to configure? (from the below case)
(There is an existing and running RSLinx on-site, but we just borrowed the license (RSLinx Classic Gateway CPR 9 SR1) from Rockwell.
We bought this new license RSLinx CPR 9 SR3 to replace the existing license.
I registered the license via internet at the office and transferred it on-site. I uninstalled the existing RSLinx and installed the new one (the one that we bought) togeteher with the registered license. But when I opened the RSView32 runtime, it is not stating on online mode. I tried to ping the SLC505 and look for it at the new installed RSLinx and it was there.
Note: I didn't create a back-up of the one I uninstalled.)
P.S. I encountered this service pack issue with Siemens' WinCC 7.0 SP1 and SP2. That's why I'm thinking if AB's service pack also matters and compatible to each other.
(fback)
LarsKBH
Re: AB RSLinx Software
Post by LarsKBH »
Hello !
The difference in versions should not give you any problems.
I think the latest version 2.57 also supporte Win7.
Have you confugured driver and IP adress for PLC in RSLinx ?
in menu->Communication->Configure drivers-> Add Ethernet->
In station mapping, write IP of PLC->Apply->Ok, and working :-)
Regards Lars
brave_eagle
Post by brave_eagle »
Thunder://QUFodHRwOi8vc3VwcG9ydC5yb2Nrd2VsbGF1dG9tYXRpb24uY29tL1dlYkZpbGVzL1VucHJvdGVjdGVkLzkzNTVXQUIxMDBFTkUvMi41OC4wMC9Db3JlLzIuNTguMDAtUlNMaW54TGl0ZS1BLURWRC56aXBaWg==
RSLinx 2.58
Pls download the "Thunder" download tools to download the link
Dr.Acrobat
Post by Dr.Acrobat »
(sorry) Where is possibile found "Thunder" please.
Christine_1914
LarsKBH wrote: Have you confugured driver and IP adress for PLC in RSLinx ?
I already did this configuration but with no positive output for the RSView32 to go online. :(
brave_eagle wrote:
Spoiler
RSLinx 2.58
May I know what is this for? I tried to open the link but my Firefox prompted a message "Firefox doesn't know how to open this address, because the protocol (thunder) isn't associated with any program."
brave_eagle
cuongvcs
Post by cuongvcs »
(gpost) (gpost)
Thank you very much
soundview00
Post by soundview00 »
Thanks.
mesta1
Post by mesta1 »
To go online with RsView you need to configure RSLinx enterprise, that it's included inside RSView and in your project too. You should also stop RsLinx Classic too from control panel.
RsLinx classic gateway is used as OPC server for other supervisors or to go online with RsLogix.
vuonganh
Post by vuonganh »
soundview00
Is this the lite, professional, or enterprise edition?
LarsKBH
Post by LarsKBH »
Without license it is Lite, with license it is Professional.
Enterprise is another software - Linx Enterprise
vuonganh
Post by vuonganh »
it is RSLinx Gateway 2.58.00 with license (installation package of RSLinx Gateway 2.58.00 )
http://www.rockwellautomation.com/rockw ... efits.html
soundview00
Thanks for the info.
neuhauser
Post by neuhauser »
I've seen similar problems in the past with linx if you don't backup the network before reinstalling. In linx classic even if you set up the drivers with the same names you will get unpredictable results going online until you re-setup the plc comm paths and save to the project.
Dr.Acrobat
vuonganh for megaupload needed premium account.
Could you upload just gateway license.
Thanks.
pftarazona
Post by pftarazona »
Samiro
Post by Samiro »
posting.php?mode=reply&f=12&t=16361#
Could someone please repost a link for RSLinx 2.58 or is there a way of cracking the activation of version 2.59?
Pleasehelp
