[?]: Error at Simatic Key Installer
yolovs
Post by yolovs »
I just trying to set some SIEMENS licenses using Simatic Key Installer 2011/02/15 under Windows XP Professional SP3.
When I am installing long keys, it turns out that I got error:
Error of containger opening: NTE_BAD_KEYSET
The dialog got OK button. Pressing the button OK shows another dialog:
Error of containger opening: NTE_EXISTS.
I can install only short licenses.
I test it with the very last release of Simatic Key Installer but I got the same result.
Did someone have an Idea why I experience such errors and how to fix them?
Best regards
Re: [?]: Error at Simatic Key Installer
http://www.google.ru/search?ie=UTF-8&hl ... BAD_KEYSET
http://support.microsoft.com/kb/238187/
If several applications use the same container, one application may be altered or deleted keys, another application must be available.
If applications use key containers with a unique name of the other applications that change data with keys that are needed to reduce the risk properly.
