hello,
I have a draft of a remote network of drinking water supply with Vijeo Citect V6.1, the network consists of six pumping station communicating in GSM / GPRS module via the W @ de W315 Telemecanique, each station is controlled by a PLC Telemecanique M340.
However, I am not good with Vijeo-Citect, I had the opportunity to work in Monitor-Pro V7.2 and I assure you it's totally different.
In fact, on my Monitor Pro direct access from the windows that I create a VBA editor in which I edit my job, I run the animation, I access the SQL database, I compile and debug my free program, in the end I can manage easily.
On-Vijeo Citect these opportunities are very complicated (I do not know where to start).
I decided to spread this message to people who have the documentation, and knowledge that will allow me to launch myself on Vijeo Citect, including the handling of VBA scripts and functions in the windows.
I know that among the features offered by Citect Vijeo-there are a publisher Cicode that allows the programming of scripts in Cicode and VBA, but I do not know how to handle the management of my windows (eg a function to launch Opening a page, execute a procedure when I press a button ...).
In addition, if you have such a project do not hesitate to offer me help.
Regards.
Spoiler
Message En Français:
Bonjour,
j'ai un projet de télégestion d'un réseau d'adduction en eau potable avec le logiciel Vijeo Citect V6.1, le réseau est composé de 6 station de Pompage communicant en GSM/GPRS via le module w@de W315 de Télémécanique, chaque station est contrôlée par un automate M340 de Télémécanique.
Cependant, je me trouve pas bien avec Vijeo-Citect, j'avais l'occasion de travailler sous Monitor-Pro V7.2 et je vous assure que c'est totalement différent.
En effet, sur Monitor pro j'avais accès directement depuis les fenêtres que je crée à un éditeur VBA sur lequel j'édite mes fonctions, je gère l'animation, j'accède à la base de donnée SQL, je compile et débugge mon programme librement, en fin je peux me débrouiller facilement .
Sur Vijeo-Citect ces possibilités m’avèrent très compliqué (je ne sais pas d'où commencer).
J'ai décidé de diffuser ce message aux personnes qui disposent de la documentation, et du savoir faire qui me permettra de me lancer sur Vijeo-Citect notamment la manipulation des Scripts et fonctions VBA dans les fenêtres.
Je sais que parmi les fonctionnalités offertes par Vijeo-Citect, il existe un éditeur Cicode qui permet la programmation des Scripts en Langage Cicode et VBA, mais j'ignore comment le manipuler dans la gestion de mes fenêtres (par exemple lancer une fonction à l'ouverture d'une page, exécuter une procédure lorsque j'appuie sur un bouton...).
En plus, si vous avez déjà réaliser un projet pareille n'hésiter pas à me proposer de l'aide.
Cordialement.
Bonjour,
Cordialement.
